steadyshot
- Mar 14, 2023
For Those who tried it , when you do room correction what is the max gain you saw ? Does it auto correct the volume meaning auto headroom adjustment?
In the first beta it was capped at 10db and I believe that was reduced to 6db in second beta (can't check that right now, may be 5). Not sure on your second question...afaik it's just a case on +or- up to 6db at 10 points across the spectrum.For Those who tried it , when you do room correction what is the max gain you saw ? Does it auto correct the volume meaning auto headroom adjustment?
I remember it was from 10db to 6db on second firmware.In the first beta it was capped at 10db and I believe that was reduced to 6db in second beta (can't check that right now, may be 5). Not sure on your second question...afaik it's just a case on +or- up to 6db at 10 points across the spectrum.
If you have beta firmware, you will need to download the app from WiiM's servers.New beta says 10 band PEQ. still only shows 4. Or at least 4 presets
The 10 band and room correction had beta firmware and need test flight wiim app. I’m one of the beta tester so I have all the above features.New beta says 10 band PEQ. still only shows 4. Or at least 4 presets
I’m just guessing but getting beta firmware at this stage may already been close.How long does it take after I provided my MAC address for them to set me up ?
Wut? Can you provide the prompt you used?Just found out chatgpt can cacluare peq values with a measurement graph. Cant wait to have 8 bands! I will just use my newly purchased umki1 and ask chatgpt to do RC!
I signed up long time ago but not even selectedHow long does it take after I provided my MAC address for them to set me up ?
I wouldn't mind getting my invite also @WiiM TeamI signed up long time ago but not even selected
Edit: Finally got the beta firmware. Thank you very much!!!!
As far as I can see, they’re still under development. I’m sure WiiM will say something formally once it’s all set up@WiiM Team @Brantome
May be you can or want to tell something about new procedures for inviting people for beta testing?
Me neither. I Would love to test RC. Signed up on day one, but wasn't invited.I wouldn't mind getting my invite also @WiiM Team
