It would be really nice to have EQ working with Bluetooth out. As far as I can tell it does not work, Also, I noticed that if the input sensitivity settings do not work with Bluetooth. It seems like once you choose Bluetooth output all setting are automatic and only volume works no matter the input source. I noticed this when the Bluetooth output seemed to strong and started sounding bad with analog input I tried to adjust it to no avail.. By bad sound I mean over peaking and distortion.
Yes, I am aware that Bluetooth output is not the best sounding output option. I do know that the current Bluetooth output can be improved.
Thanks
Thanks
