That's not an answer.
If the only defense of Folder View was "You can't go wrong with folder view", you wouldn't accept that, and rightly so.
FOLDER VIEW? ROFL.
You asked how you’d tag files to reflect things. That is the answer. You set the RELEASTYPE tag to one of those values.
picard facepalm. I just showed you a screenshot with various types, singles, albums. Here I'll post it again.
It doesn't matter it's not the beatles. irrelevant.
That is the answer if you're set on using the onboard indexing.That's not an answer.
Specifically, from start to finish.
You're hiding behind jargon.
From what I can see there's no solution, and you're not even prepared to offer an explanation.
FOLDER VIEW? ROFL.![]()
What’s your point?
That's folder view?
That looks decent enough but what about multi disc albums? in a 20 disc set, having them all in one folder is a mess, but on mine under \cd10 \cd11 etc, but the scanner when it seems them puts them in one big list. So I don't need to browse \cd10 folder
What about combination of lossy and lossless files? I have \flac\ and \mp3 for example as well as \singles\ op
WIth each one, and you'd do mass tag of all, ie in foobar you would drag all EP folders from every band into playlist and mass edit. Then do the same for albums, compilations etc.
Also in your system you wouldn't be able to see these, where pet shop boy songs are in other albums, as those are in different locations, the "Now" albums are in \various
So it won't "link to" other folders, nor will it link to "appearances" ie duet with elton john, as that would be in \elton john directory.
You need ensure tags are sorted, artist, album, title, track etc. Easy to mass tag a whole artist branch, not to bad with album but track - nah. But there is a method to retrieve tag from filename as long that's ok. Tag and rename or foobar will do it.
If I have a multi-disc box - let’s say 10 disc - I have one folder for the box, containing 10 sub folders, one for each disc.
When I ripped them they were put each in its own folder, but the 10 folders weren’t in a master folder for the whole box. Takes 30all seconds to create, name, drag all 10 folders in, and copy some album art in.
I see what you mean, but that’s not an issue for me.
I’m pretty sure that I don’t have an artist folder where a track on a compilation isn’t already in that folder anyway.
Example - U2. There are a few U2 tracks on compilations (Now, etc.) but they’re already in the U2 folder under ‘Singles’.
Has that answered your question, or have I misunderstood?
Unless he copies those tracks to:You've misunderstood.
If you navigate to \artist\u2, you'll see that album and files, that's ok
But you won't see
Now 102- best of 90's \ U2 - Zooropa
Best of 90's hits\U2 - Indie\ U2 - achtung baby
\artist\u2\Appears On\Now 102\
\artist\u2\Appears On\Best of 90's hits\
Code:\artist\u2\Appears On\Now 102\ \artist\u2\Appears On\Best of 90's hits\
