Connecting an external dac to my Ultra
Bozzz
Senior Member
An audio friend of mine gifted me a fiio k11r2r dac. Haven’t received it yet but when I connect it I’ll either use USB or coaxial. If I use USB will that connection power the dac or will I need to hook it I to external power also?
My only WiiM is my Pro and together with the FiiO R2R it is everything I expect from streaming. For me the difference between NOS and OS is quite significant, the possibility to switch is fine. Big orchestras NOS, small ensembles OS. Or vice versa ;-)
The only missing feature could be a remote. Highly recommended for a casual listener. No idea how it measures, for a more modest user like me its great.
Did you connect via coax usb or optical?
Coax, no USB chance with the Pro ;-) Coax only because a fitting 30 cm cable was here, the shortest optical cable in stock here was not so good to hide.
