motleypixel
Active member
- Jul 12, 2025
Another set confirmed NOT to work, they have random quick drops: Anker Soundcore Life Q30
Yes. Same issue. Bought Sony xm4 and tried all my Wiim products BY out (mini, pro & ultra) but after usually 10 mins of perfectly fine use the xm4 started to play up …. Distorted sound, unlistenable. Informed Wiim of the issue and returned the xm4’s. Wiim never provided a reason or solution.
It’s reassuring that others have had the same issue….shame as I liked the xm4’s but as my use was intended with Wiim products, they had to go back. Now not willing to risk another BT headset.
WH-CH720N has BT 5.2 and experiences the issue.Could it be that the issue is with the Bluetooth version? The Sony XM-4 is BT5.0 while the WiiM Ultra Support 5.3.
It should be backwards compatible but maybe not with the WiiM implementation?
What is the BT version of the other headphones that has issues?
I got the Sennheiser momentum 4, with BT 5.2, that works with no issues.
Ok. So seems to be an issue primary with some Sony headphones when recovering from a bad connection.WH-CH720N has BT 5.2 and experiences the issue.
Wonder if there might be an interference issue in your house. Here's an experience I had several years ago with wif-fi in a prior house. Everything worked find except for one Roku receiver on a TV in the kitchen where the connection was poor. Finally it occurred to me one day that there was a laundry room with a large washer & drying directly in the path between the wireless router and the Roku. Moving the wireless router about 4' to the left solved the problem. You might have a similar issue with the BT connection -- could be a metal HVAC air duct hidden in a wall or something similar. Also some devices have a better chip or antenna setup than others, or another device just emitting RFI that's interferring. Just a thought....Anker Soundcore Life Q30 BT 5.0 and doesn't have issue of poor quality streaming, they just briefly drop connection for a sub second randomly but do so the further I get from the Ultra, maybe once every avg. song when only 8' away but multiple times if I go further than 20ft.
Never had issues with a FiiO BTA30 Pro DAC that is a BT transceiver with antenna. Never ever, same spot where the Ultra sits.
I tested the Ultra's Bluetooth here. Before you buy a new headphones more, it might be a good idea to take the Ultra out into the garden and test it. If you can.
I don't feel the WiiM Ultra BT is weak as much as I wonder if there could be various ways to implement BT 5.3 in ckt? Again, what I'm seeing are more issues with prior ver. BT headphones vs 5.3 headphones. I never had issues with my XM-4 BT 5.0 with my FiiO BTA30 Pro BT 5.0 BT/DAC in the same spot as the WiiM. I just want to find an answer as to why this BT5.3 Ultra implementation is having so much issue with headphones that are not BT5.3? Because it should be fully backwards compatible.
Thank you.
Here's a use case: usb-cd to LMS to mini to bt headset (or to any other lms endpoint).Of course, WiiM offers bt so you should have the chance to connect your hires codec filled headphones to the device. You know, all this LDAC and aptx will be ignored and you end with SBC. But you want to do it anyway.
My question is: Why? You have your Android phone or tablet you likely bought the headphones for. The use case with a WiiM really does not make sense for me. Where a WiiM is doing it's job there has to be a wifi or ethernet connection. So wtf is the reason for bt here?
Don't get me wrong, I love my bt headphones. But for what I've bought them. For phone or tablet.
