steadyshot
Senior Contributor
- Mar 14, 2023
I was (still am
) waiting this firmware with excitement! I have requested this feature and Wiim delivered!
I'm inclined to agree. IIRC a while ago someone asked for a 'bit perfect' switch which would disable volume and EQ in one go. The case for such an option is stronger now. As it stands I need to check that (a) vol is fixed, (b) limiter is 100% and (c) EQ is off to ensure bit-perfect. (Or run bit tests through my ADI-2.)To me, it seems like a bug to have the limiter enabled when using fixed volume output. It is just confusing and not what people will want in the vast majority of cases where fixed volume is used.
But surely you’d only do that once? Why would you need to constantly recheck it?I'm inclined to agree. IIRC a while ago someone asked for a 'bit perfect' switch which would disable volume and EQ in one go. The case for such an option is stronger now. As it stands I need to check that (a) vol is fixed, (b) limiter is 100% and (c) EQ is off to ensure bit-perfect. (Or run bit tests through my ADI-2.)
Even I can handle it although switching these settings all the time on all my WiiMsBut surely you’d only do that once? Why would you need to constantly recheck it?
Not constantly, but it's a convenience thing to be able to simply toggle off all DSP. The case was borderline with two variables (vol, EQ) but IMO is stronger now the limiter has been introduced (which is evidently mis-labelled since it's a scaler not a limiter).But surely you’d only do that once? Why would you need to constantly recheck it?
so I've been skimming this blurb and just had to mention something not addressed hereIf volume set on fixed, will volume limit has no effect?
Well, that's not how it works...so I've been skimming this blurb and just had to mention something not addressed here
if you want a lower output, without affecting the "bit perfect-ness" of the signal, you can lower the output level to 1 V or less is you find these loudness wars music to overdrive your equipment
However, keep in mind that this affects only the analogue output, and not the coax or s/pdif outputs
There's also ways to have your software adjust levels, but again, not with a "bit perfect" output
I was using plexamp and seen they offer such a setting, to "normalize" levels
I realize lowering the output votage has nothing to do with "bit perfect-ness" but if the songs we play are overloading the preamp/amplifier chain, the reason people are asking about lowering the level in the first place, using the analogue output with a lower output can simulate the effect inquired about here, without affecting the "bit perfect-ness" of the digital chainWell, that's not how it works...
Lowering the analog output voltage has nothing at all to do with maintaining a bit perfect signal into the wiim's dac.
You'd still need to do all the other checks mentioned above (including mono off and probably others that have been forgotton) to get no digital manipulation of the signal.
I'm assuming that the 'single button' to achieve this will still be in the mqa menu options, and it would disable /reset anything at all that adjusts the signal.
Fair enough, but I read "if you want a lower output, without affecting the "bit perfect-ness" of the signal..."I realize lowering the output votage has nothing to do with "bit perfect-ness" but if the songs we play are overloading the preamp/amplifier chain, the reason people are asking about lowering the level in the first place, using the analogue output with a lower output can simulate the effect inquired about here, without affecting the "bit perfect-ness" of the digital chain
That's my point here
exactlyFair enough, but I read "if you want a lower output, without affecting the "bit perfect-ness" of the signal..."
Plus, the signal may already be clipped by that time.
Especially when lowering the analog output level is performed internally by lowering the signal in digital domain.using the analogue output with a lower output can simulate the effect inquired about here, without affecting the "bit perfect-ness" of the digital chain
Ah....Especially when lowering the analog output level is performed internally by lowering the signal in digital domain.
I'm not an Onlyoneme.@onlyoneme
Sorry, but I still don’t get it…
Can you please give a real life example of the usefulness of this volume limiter?
In other words, why has it been introduced?
Yes it’s there in my iPhone appIt's only for iOS atm.
And to add a bit more than my simple "ah" earlier...Especially when lowering the analog output level is performed internally by lowering the signal in digital domain.
