Grounding issue Amp Ultra with LG G4
Larrie
Hello,
I've recently bought the WiiM Amp Ultra and connected it to my LG G4 (via HDMI) and Triangle Color Colonne floorstanders. The TV is also linked to an Apple TV through HDMI. All devices are plugged into the same grounded wall outlet, which I recently tested with a socket tester. Of the three devices, only the WiiM is grounded; both the TV and the Apple TV lack a ground pin and are to my best knowledge 'floating'. I don't have any coax or ethernet connected to the TV, though the Apple TV is connected via ethernet to a wall outlet.
Whenever I turn on the TV and the WiiM switches to HDMI, I get a variably loud pop through the speakers. I also notice a visible electrical arc when I hold the TV’s HDMI cable close to the WiiM. This makes me think there might be a grounding issue or a ground loop. However, there is no audible hum, which is usually described in discussions about ground loops. What I also find odd is that this never happened with my previous setup using a grounded Denon AVR.
I've already tried two other wall outlets, two other power strips and two HMDI cables with no effect.
Could this indicate a faulty unit? Or is there anything else I might try to solve this problem?
Cheers,
Larrie
EDIT: I just realized that my old receiver wasn’t actually grounded; it only had a cable that looked like a grounded one. That probably explains why I never had any issues before.
Below is my (floating) TV's stand to ground. No pop, and still alive, but I use optical to Wiim Ultra (floating as as well).
Still, I'm worried.
EU here so 220V
That's totally normal with class 2 (un-grounded) devices. It's called leakage current and you will measure about half the line voltage.
Good to know, and that makes sense. Still I get small electrical shock from time to time when touching the TV. At least I know this should not hurt anyone as very low current.
