How about connect ultra to vibelink using bundle rca cable ?
bakus9
Hello everyone^^
I will match vibelink to B&W 705S3 using Ultra.
For sound quality, I'm trying to connect the Ultra and Vibelink via RCA cables for a warm and expansive soundstage sound.
Will it be okay to use the bundle RCA cable provided Wiim?
The provided RCA cable is perfectly fine for an analogue connection between the WiiM Ultra and the WiiM Vibelink Amp, using the slightly older DAC of the Ultra.
The included optical cable is perfectly appropriate for a digital connection between the WiiM Ultra and the WiiM Vibelink Amp, using the slightly newer DAC of the Vibelink Amp.
What makes you assume that you must use the analogue line level connection to get a "warm and expansive soundstage sound"? You can try both options (at no additional cost) and see for yourself if you prefer one over the other. :)
