Good afternoon, guys, and I do appologize if this has already been asked and replied before.
I did try and do my homework, but I couldn't find a conclusive answer, so, I thought it would be best to ask the experts, before losing more time in a solution that might not even exist.
This my current use case scenario.
The WiiM Pro Plus is connected to an amplifier which has passive speakers connected to it. This is the main system.
But I want to be able to connect multiple active smart speakers through DLNA to the WiiM Pro Plus, so that I can listen to music in different parts of my house.
I know the Xiaomi Smart Speaker is working properly, as if I use Qobuz App on the phone instead of using WiiM Home App, I just have to click on the dlna mirror stream sign and set it to stream to the Xiaomi Smart Speaker.
Problem is, on the WiiM Home App, I don't see any dlan mirror stream sign, and when I go to devices and try do add a device, the Xiaomi Smart Speaker simply doesn't show.
I also tried to see if it appeared under the audio output choices, but it also doesn't.
I'm starting to think that I can't use the WiiM Home App, and will have to use the Qobuz App instead.
Any help will be appreciated!
Thanks!
Thanks!
