Introducing WiiM Sound: Your Smart Speaker for High-Res, Room-Filling Audio
AD_4nXd9pdn5vmIdlsudC_j9YSDmAoxv_PDGzsGsQ_qRgTDTlpl8aks5RZDcXq_fs3ruWLl6DHuJNaslVKO07_oYYg306NlhTpiL7wMaNyTXNvwnz0xhGTN08De4Kv1JUDqgkInpT8RZ
📢A landmark moment for WiiM! WiiM Sound, our first WiiM designed smart speaker, is here! The WiiM Sound is crafted from the ground up to deliver exceptional audio fidelity, smart connectivity, and seamless integration with the WiiM ecosystem.
After years of delivering award-winning streamers and amplifiers, we listened to our community and built WiiM Sound to fill a major gap in high-resolution, multi-room smart audio. With 24-bit/192 kHz playback, built-in room correction, and advanced EQ customization, this speaker adapts to your space and sound preferences like never before.
AD_4nXdltF_exblU5Ku1jhxDkd8_GFsA4fIb_3PU7yLrZGs6vOwd6l4g09d5GYgrO1PW905wEInLGpRZ3RMD34RYXzQv_BXFMQm39_ExgLVHm5N0fLc_O6l2WXEpsJxAoegUdHdJN_Io1Q
Why WiiM Sound?
  • High-resolution wireless streaming: Enjoy music, podcasts, Smart Preset and radio in stunning 24-bit/192 kHz quality—no phone required.
  • Next-generation connectivity: Equipped with Wi-Fi 6E, Bluetooth 5.3, and 100 Mbps Ethernet for fast, reliable streaming.
  • Advanced sound customization: Tailor your sound with 24 preset EQ profiles and a 10-band graphic and parametric EQ for precise adjustments.
  • RoomFit: Previously Room Correction, actively takes precise acoustic measurements of your room, crafting customized corrections for your audio equipment.
  • Stereo pairing: Seamlessly pair two WiiM Sound speakers to create a left/right stereo setup and expand your soundstage.
  • Home theater integration: Functions as a surround or center channel speaker in a Dolby 5.1 setup for immersive home cinema experiences.
  • Universal casting support: Stream directly from your favorite music apps using Chromecast, Spotify Connect, TIDAL Connect, DLNA, or Alexa Cast.
Immersive, Smart, and Customizable Sound
Whether placed on a shelf, counter, or wall-mounted, WiiM Sound seamlessly blends into any space while filling it with room-filling audio.
✅ 100W power delivered through a 4” woofer and dual tweeters
âś… Automatic room correction for personalized acoustics
âś… Stereo pairing - connect two for a true left/right speaker setup
âś… Multi-room sync - stream across your home with WiiM, Google Cast, or Alexa multi-room
High-Resolution Streaming & Universal Casting
🎵 Stream from over 20 music services or your personal library via the WiiM Home App
🎶 Enjoy effortless playback with Chromecast, Alexa Cast, Spotify Connect, TIDAL Connect, DLNA
🎤 Control hands-free using Alexa, Google Assistant, and the WiiM Voice Remote (WiiM Voice Remote included).
Powerful Connectivity & Customization
🔌 Wi-Fi 6E, Bluetooth 5.3, 100 Mbps Ethernet, 3.5mm Aux input for versatile connectivity.
🎛 Advanced EQ tools, including our 10-band graphic & parametric EQ, 24 preset EQ profiles, and input-specific adjustments.
🖥 1.8” high-res touchscreen display for direct control, album art, presets, and wallpapers.
🎭 Home Theater ready, use WiiM Sound as a surround speakers in a Dolby 5.1 setup with a WiiM device that has an HDMI ARC input such as the WiiM Amp Ultra.
Always Improving with Continuous Updates
🔄 Regular firmware updates unlock new features, services, and audio enhancements
Tech Specs
Connectivity: Wi-Fi 6E | Bluetooth 5.3 (SBC, AAC, LD3) | Ethernet | 3.5mm Aux
Sound Performance: 35 Hz - 20 kHz, 100W total output
Streaming Platforms: Chromecast, Spotify Connect, TIDAL Connect, DLNA, LMS
Multi-Room Audio: WiiM | Google Cast | Alexa Multi-Room
Smart Preset & Alarm Clock for personalized listening.
Dimensions: 5.7” x 5.7” x 7.5” (146 x 146 x 193mm)
Weight: 5.5lbs (2.5 kg)
Pricing & Availability​
WiiM Sound launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com.
Anyone know if it will be possible to connect to a TV and use two speakers as a front R/L?
That is a feature that would really appeal to me.
You'll need one of the WiiM devices with an HDMI Arc input to get the audio signal from the TV to start with. With the current software, that device acts as the front right and left channels, and we've got some beta software where you can add a center channel wirelessly. Then the WiiM Sound can act as surround left and right.
We've heard some requests about adding the WiiM Sound as the front right and left channels as well, which isn't currently available but the team is looking into it. So this might come in the future.
Thanks Ryan.
I have been interested in buying smart speakers in the past but I have always been put off as (the ones that I have looked at) can’t be used as front L/R speakers. If WiiM Sound had that capability I would very quickly part with my money.
Do you know yet when these will be available to purchase in Australia, and is there any price estimate at this stage please?
The best estimate I have on time right now is Q3 2025, and no, we're not quite ready to share price estimates yet.
@WiiM Team - Are the two balanced mode radiators fed different left and right signals when a single WiiM sound is used?
What's the crossover frequency to the 4" woofer and how are the BMRs positioned in the enclosure?
Yes.
The crossover point is around 2.5 kHz. The two drivers are positioned at a 90° angle to each other, each angled 45° from the front center. Hope it clarifies.
Thanks for clarification. I had originally expected a somewhat lower crossover frequency, but that was probably a little naive.
I could dig this if it were battery operated, so i could take it outside with me.
With a long enough outdoor power cable, many things can be made portable :)
But I'll pass along the request for something battery powered. The WiiM Sound isn't recommended for outside use in general, as it's not weather protected, so that'd probably be on the list for such a product.
You probably wouldn't take it outside if it was raining 🙂
I think the most interesting area of use for many people would be to connect two Wiim Sound wireless to the Ultra or Amp Ultra and use as Surround left and right speaker with LCD screens turned off. If this works with a wired stereo setup with subwoofer and virtual center speaker it will sell as hot cakes. With wired I also mean Ultra connected to Internet by Ethernet cable and just the Surround L and R Sound speakers connected wireless. This could give us a nice and cost effective Dolby 5.1 Surround system from HDMI connected TVs. I am not sure if this will be possible. Maybe the Ultra/Amp Ultra must be using WiFi for this Dolby 5.1 setup to work?
