Introducing WiiM Sound: Your Smart Speaker for High-Res, Room-Filling Audio
AD_4nXd9pdn5vmIdlsudC_j9YSDmAoxv_PDGzsGsQ_qRgTDTlpl8aks5RZDcXq_fs3ruWLl6DHuJNaslVKO07_oYYg306NlhTpiL7wMaNyTXNvwnz0xhGTN08De4Kv1JUDqgkInpT8RZ
📢A landmark moment for WiiM! WiiM Sound, our first WiiM designed smart speaker, is here! The WiiM Sound is crafted from the ground up to deliver exceptional audio fidelity, smart connectivity, and seamless integration with the WiiM ecosystem.
After years of delivering award-winning streamers and amplifiers, we listened to our community and built WiiM Sound to fill a major gap in high-resolution, multi-room smart audio. With 24-bit/192 kHz playback, built-in room correction, and advanced EQ customization, this speaker adapts to your space and sound preferences like never before.
AD_4nXdltF_exblU5Ku1jhxDkd8_GFsA4fIb_3PU7yLrZGs6vOwd6l4g09d5GYgrO1PW905wEInLGpRZ3RMD34RYXzQv_BXFMQm39_ExgLVHm5N0fLc_O6l2WXEpsJxAoegUdHdJN_Io1Q
Why WiiM Sound?
  • High-resolution wireless streaming: Enjoy music, podcasts, Smart Preset and radio in stunning 24-bit/192 kHz quality—no phone required.
  • Next-generation connectivity: Equipped with Wi-Fi 6E, Bluetooth 5.3, and 100 Mbps Ethernet for fast, reliable streaming.
  • Advanced sound customization: Tailor your sound with 24 preset EQ profiles and a 10-band graphic and parametric EQ for precise adjustments.
  • RoomFit: Previously Room Correction, actively takes precise acoustic measurements of your room, crafting customized corrections for your audio equipment.
  • Stereo pairing: Seamlessly pair two WiiM Sound speakers to create a left/right stereo setup and expand your soundstage.
  • Home theater integration: Functions as a surround or center channel speaker in a Dolby 5.1 setup for immersive home cinema experiences.
  • Universal casting support: Stream directly from your favorite music apps using Chromecast, Spotify Connect, TIDAL Connect, DLNA, or Alexa Cast.
Immersive, Smart, and Customizable Sound
Whether placed on a shelf, counter, or wall-mounted, WiiM Sound seamlessly blends into any space while filling it with room-filling audio.
✅ 100W power delivered through a 4” woofer and dual-balanced mode radiator tweeters
✅ Automatic room correction for personalized acoustics
✅ Stereo pairing - connect two for a true left/right speaker setup
✅ Multi-room sync - stream across your home with WiiM, Google Cast, or Alexa multi-room
High-Resolution Streaming & Universal Casting
🎵 Stream from over 20 music services or your personal library via the WiiM Home App
🎶 Enjoy effortless playback with Chromecast, Alexa Cast, Spotify Connect, TIDAL Connect, DLNA
🎤 Control hands-free using Alexa, Google Assistant, and the WiiM Voice Remote (WiiM Voice Remote included).
Powerful Connectivity & Customization
🔌 Wi-Fi 6E, Bluetooth 5.3, 100 Mbps Ethernet, 3.5mm Aux input for versatile connectivity.
🎛 Advanced EQ tools, including our 10-band graphic & parametric EQ, 24 preset EQ profiles, and input-specific adjustments.
🖥 1.8” high-res touchscreen display for direct control, album art, presets, and wallpapers.
🎭 Home Theater ready, use WiiM Sound as a surround speakers in a Dolby 5.1 setup with a WiiM device that has an HDMI ARC input such as the WiiM Amp Ultra.
Always Improving with Continuous Updates
🔄 Regular firmware updates unlock new features, services, and audio enhancements
Tech Specs
Connectivity: Wi-Fi 6E | Bluetooth 5.3 (SBC, AAC, LD3) | Ethernet | 3.5mm Aux
Sound Performance: 35 Hz - 20 kHz, 100W total output
Streaming Platforms: Chromecast, Spotify Connect, TIDAL Connect, DLNA, LMS
Multi-Room Audio: WiiM | Google Cast | Alexa Multi-Room
Smart Preset & Alarm Clock for personalized listening.
Dimensions: 5.7” x 5.7” x 7.5” (146 x 146 x 193mm)
Weight: 5.5lbs (2.5 kg)
Pricing & Availability​
WiiM Sound launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com.
I do wish that they would at least give us the prices, as I want to get the speakers for family members and myself for Christmas.
Also, a quick question, are there going to be stands and wall brackets available at launch?
A quick question, for anyone knows.
I’m thinking of gifting one of these to my daughter, if it’s out in time for her birthday.
She currently has something ‘similar’, but it’s tiny, and little more than a toy. What she likes is that she can play her music on her phone, connect to the speaker via Bluetooth, and her music comes out of the speaker.
Would she be able to use this speaker in the same way? Or would she have to learn to use the WiiM Home app?
If it needs an initial set up, obviously I can do that for her. But after that, can she just use it as a Bluetooth speaker, without opening the WiiM Home app every time she wanted to play music?
I think ultimately she’d get to use all WiiM’s bells and whistles, but starting from scratch, it might put her off a bit.
Thank you.
Thank you.
Hi Steve,
WiiM sound can work as the standard Bluetooth speaker without using the WiiM Home App.
Hi @claudia.bailey! Great to hear you're considering WiiM Sound as gifts :). They will be great gifts! We're still finalizing the pricing, but when it's available, we'll share it. We're also looking into having stands and wall brackets available. Can you share your use case for the stands and wall brackets? Thanks!
Will this speaker be able to handle Atmos encoded audio tracks from Amazon Music (similar to the Echo Studio)?
Living in a smaller space, it would be great if these could be attached to the wall or a stand minimum. Also, if using these as part of a movie setup, it would just be too many speakers on stands. As for family, if one is put in the kitchen for them, it would be great if this were not in a corner, but again, with a wall bracket, you could take it off the surface.
Besides the different room correction and I guess easier integration within a WiiM ecosystem… what would be the major benefit(s) of a WiiM Sound vs the Echo Studio?
I have no interest at all in the tiny screen of the Sound.
Answered on the other thread.
It would be good to have USB input for music files, (or inbuilt flash drive) this is useful also if you are using it as a bedroom alarm clock etc.
I’m pretty sure it does.
EDIT: Actually no, I was thinking of 3.5mm six input.
The only speakers that I know have this feature is the Denon Home series
I currently own the home 250 and have a 2tb hard drive plugged into it and a WiiM mini
It also has Qobuz connect as well 😊
Q. for @RyanWithWiiM
Does the WiiM Sound amplifier have the same post filter feedback loop introduced in the Amp Ultra?
I've still not heard from WiiM if the Sound will be released in Australia, but I wonder how similar it might be to this?
