How to use Room Correction?
It looks fine. Have you tried independent Left/Right room correction? You could also try only correcting up to 400-500Hz. If you save your current results you can easily return to them.
This is the result with individual L/R calibration. And a picture of my setup seen from listening position
I’m going to mock around with the speaker placement over Easter. Is the consensus still to have the subwoofer in the around the middle of the two speakers?
Nope
Use rew room SIM to get an idea where best placement of sub will be
I have fallen into the RC rabbit hole, and trying to find a way out.
I have changed my listening position and speaker to what would be the optimal choice, forgoing any aesthetic considerations.
So I’m staring from scratch:
- Unilateral triangle position
- Started with sub woofer settings: Wiim SW setup to get the delay right, tried different SW positions, played around with the cross over. Ended up with a satisfactory placement of the SW, set the Wiim Cross over to 110 Hz, and most likely the same setting on the actual SW. Question: should the Wiim Cross over and the SW knob be used concurrently ?
- Then moving on to Room Correction - seems like I forgot to exclude the sub cross over range in the RC setting. So I should only perform RC from 120+ Hz to 1000 Hz?
- Also in doubt about the upper value for range. Consensus seems to be anything above 400 Hz is correcting the speaker sound profile rather that correcting the room.
- My next steps is to play around more with RC, then get started with REV.
Any help or suggestions are great appreciated.
Peace and love,
/S
No, the subwoofer's crossover should generally be disabled (if possible) or set to the highest possible value, so it doesn't get into the way of WiiM's subwoofer management.
By now, WiiM's RC algorithm should work well including the subwoofer range, no need to exclude it.
Exactly. You can still try automatic correction up to higher frequencies. It might or just might not work out well. If it does, there's nothing to worry about. If it doesn't ... well, we told you it might not improve things. :) Just go with what you prefer.
REW can give you a lot more insight into what's going on. But there's nothing wrong with using the WiiM RC for a start. (y)
