Thank you, just did the group search and will sort through.If the non-WiiM edition vanilla Audio Pro speakers are WiFi, then it’s likely they can be grouped with WiiM devices given, as mentioned, they have Linkplay modules at their core and from what I recall of the audio pro app, it’s a cut down less feature rich version of the WiiM home app. However, I recall owners saying they’re visible in the WiiM app.
Audio Pro speakers have been mentioned in the forum in previous posts - maybe a group search for audio pro will be helpful.
Is it not also the case that the A10 Mkii (WiiM edition or not) can’t be grouped with echo devices or used as echo group preferred speakers as they don’t support Alexa, whereas a Pro Plus can? Also, the WiiM editions will support Squeezelite, persistent groups and smart presets, and are likely to be Roon Ready at some point.I feel like scratched vinyl here, but so be it:
AudioPro stuff is fully compatible with the WiiM Home App and with WiiM devices. In fact the WiiM stuff is fully compatible with the AudioPro app as well. I have 3x A10 MkII's that play 100% with my WiiM Pro Pluses. The only thing I can't do with my A10s that I can do with my Pro Pluses is use room correction / parametric eq. But the A10s are just little smart speakers with perfectly adequate digital tone controls, so I'm not sure lack of PEQ is meaningful.
You always have upnpbridge to fall back on, even though that has some constraints.I imagine a lot of prospective European users are looking for the squeezelite feature...
Has anybody heard these speakers. They (the originals) get poor reviews on the German Amazon.You always have upnpbridge to fall back on, even though that has some constraints.
So I agree they’re reasonably close, just not 100% compatible for all use cases![]()
I think there's a a Groups plugin within LMS. I recall trying it years ago.Absolutely. I don't use Alexa nor Squeezlite.
Persistent Groups is vaporware. Still waiting for my WiiM branded devices to receive this feature.
Linkplay is branded as a backbone for network audio connectivity that can be licensed and applied across product brands. It can be expected that different brands and different products (WiiM doesn't actually produce any speakers whatsoever) will have different inherent features, but can still be compatible in the Linkplay space. That's what we have with AudioPro and WiiM.
Overly harsh when the feature has been in beta for a whilePersistent Groups is vaporware.
If they sound better than Sonos one's that's a plus for me. Unfortunately, there are about Zero legit reviews that I can find right now...
Well, I mean I can google "reviews" for JBL Authentics, Marshall, Denon and get a bunch of results but when I look for anything "Audio Pro" not much comes back. And a few are the AI generated garbage so Just disregard them.Who you calling illegitimate![]()
(please note the smiley emoji)
I am not a professional reviewer, but I have had my A10s for almost 6 months. They replaced the Ones that I had for many years. I consider myself a casual audio enthusiast. For a $230 ~8" x 6" speaker that meshes with seamlessly with in the Linkplay space, I think they are a great value.
By my ear they have much wider dispersion than the Sonos One, a little more high frequency extension, and about the same bass response. They are well made and come from a company that has been around for decades.
So to clarify, anything that is considered a Linkplay speaker will work seamlessly with Wiim?Who you calling illegitimate![]()
I think the Mkii do have Chromecast iircThere are other differences too, no Chromecast on the Audio Pro,
