wiimamp user
- Jan 12, 2024
He plays them in stereo later in the video.I don’t know if I can only listen to just one speaker. I’m used to one speaker per ear like in stereo.
What an great sounding speaker (s).
Thanks, on mobile I skipped over this post.See comment #25
Can someone clarify what these are? Looks like Sonos speakers, but made by WiiM.
Yes. Yes. Yes, with each other and with your WiiM devices.Are they controlled by the WiiM app? Do they effectively look to your phone like the other WiiMs? Can they be grouped, etc.?
I've updated the original post here to remove Alexa control, I must have misread something and it slipped through the edits. The Amazon product listing is correct. I'll let you know if I hear anything about Alexa control being added as a capability.They’re made by a Swedish firm with a long pedigree in speaker production. They have always included Linkplay modules with tailored versions of firmware from the same stable as WiiM, much as other third party system integrators have done (like Edifier etc)
Edit: if you download their own Audio Pro app, you’ll see they share a very common look and feel with the WiiM app - indeed, you’ll see your WiiM devices there too, just not with all the features you’ll see in the full WiiM app. One thing the audio Pro app does have that I’ve asked WiiM to include for WiiM devices is a “talk to Alexa” feature which acts like a software remote mic.
Edit #2: I think we need WiiM to answer my earlier query re Alexa/ AlexaCast as the Amazon product pages now have no mention of either![]()
I already own the following Audio Pro speakers:I'll double check that I have the right info there, I'll let you know if a typo slipped in.
There are some hardware differences separating the normal A10 MKIIs from the WiiM Editions. The WiiM Editions are built for the WiiM OS, while they're also going to work with Audio Pro’s multiroom system, the WiiM Edition offers more advanced multiroom features and will continue to evolve with regular software updates.
That's what I was wondering about if you buy one now_ could even be a second handed one _ one can use this the same as the WIIM edition?I already own the following Audio Pro speakers:
2xC5 MkII
2xC10 MkII
1xA15
They all work seamlessly with the WIIM app with full multi-room capabilities.
I think the “Wiim-edition” addition to the name is a great marketing move to signal that Audio Pro use the more well known WIIM-brand rather than the less known “linkplay” technology, which WIIM is based on. So in essence no hardware difference but a major branding move, which I applaud…
I want to have all the functionalities within the WIIM app.
Are you sure there is no difference?
Thanks for your reply.As long as it’s MkII C5’s, C10’s or A10’ I don’t think so. The Audio Pro app and the Wiim app are - besides different colours - the same, which is due to both being based on Linkplay technology, which powers both WIIM and Audio Pro. I also downloaded a host of other Linkplay apps and it’s the same (4stream, AudioCast, ieast, Omnia receiver, Vifa Home and ElipsonMultiroom). Its all the same technology (Linkplay) and the same OS and functionality.
I suppose one difference will be that the WiiM versions have Squeezelite but that is only important if you use LMS.Thanks for your reply.
Still i hope i can use the WIIM app with all the functionality im familiar with and very happy with
I also want to have Tidal connect, EQ or sub options. As I said all the functionality I have now with the amp..
I don’t own a WIIM device yet (but am planning on buying one for a set of B&O speakers) so they can play synchronous with my Audio Pro speakers. This might not work (as Audio Pro only makes the speaker part) but have you tried downloading the Audio Pro app and see if it sees your WIIM device….Thanks for your reply.
A10 MKII works seamlessly in the WiiM Home App, but it does not have the eq and room correction functionality that the WiiM devices have, which I believe has a fundamental firmware/hardware aspect.Thanks for your reply.
Audio pro app sees my WiiM Ultra, no problem.I don’t own a WIIM device yet (but am planning on buying one for a set of B&O speakers) so they can play synchronous with my Audio Pro speakers. This might not work (as Audio Pro only makes the speaker part) but have you tried downloading the Audio Pro app and see if it sees your WIIM device….
Thank you BillyBird for clearing that up!
