- Nov 6, 2022
Hi Onlyoneme,I guess you didn't mean today's release as that didn't fix it.
No, it didn’t fix in today’s release. I meant the next version. Thank you!
Hi Onlyoneme,I've decided to evaluate a latency over spdif in to spdif out.
My PC has been connected to the usb port of S2 Digi, then S2 Digi connected with a toslink cable to spdif in port of Pro, and finally spdif out port of Pro to spdif in of S2 Digi. This way I can play on S2 Digi and record the WiiM Pro output. My measurement was made in Audacity with a procedure described here:
Latency Test - Audacity Manual
manual.audacityteam.org
Signal sample rate was 96 kHz. Measured latency was around 150 ms:
It's a sum of all the latencies in the mentioned audio path. To have a clear view I've measured a latency of S2 Digi itself in the loopback:
I got around 70 ms.
I think it's safe to say that Pro's spdif in/out latency was 150 ms - 70 ms = 80 ms.
Can you give us an information on when peq will get release? Thanks!Hi Onlyoneme,
Thank you very much for your tests and the result looks great. You're pretty close. The default latency now is 85 ms and we'll open this setting with more options in our future version if people wants it shorter or longer. Please stay tuned. Thank you!
audiosciencereview.com
Pro has a lower jitter than Mini.As a result, can we say that the toslink jitter performance of wiim mini and wiim pro are close to each other? I feed wiim mini with my Allo shanti LPS, do you think this will reduce jitter?
I don't have the equipment to measurePro has a lower jitter than Mini.
I was comparing a jitter on the ASRC DAC when fed from the Pro powered by a SMPS charger and by a battery pack. I haven't noticed any difference here. I didn't compare with any LPS and it was the Pro, not the Mini though. I wouldn't expect a difference here but I've seen a report somewhere in the net that a PSU change allowed to choose more strict sensitivity setting on the selected DAC for its input.
Do you have any jitter issues?
I really doubt it could be audible. In most cases the DAC will lock to the Mini spdif clock and you will get the digital audio stream unaltered, so no even a chance to hear a difference.I don't have the equipment to measure, even if the jitter is higher in the mini, is it at a level that can be heard with the ear?
