Optical In Not Autosensing
F1 Fan
Valued Contributor
Location
Suffolk, United Kingdom
Hi all,
I’ve noticed that my ‘Optical In’ isn’t auto sensing when in use. I have to manually select it when a signal is being sent to it..
Any idea why?
Hi all,
Any idea why?
What is the state of the WiiM when you start playing to the optical input?
Auto-sensing works only when your WiiM device isn't playing audio from the current input source. For example, if your WiiM device is playing music over Wi-Fi and you start audio on Line In, Optical In, or HDMI ARC, it won't automatically switch to that input.
HDMI ARC auto-sensing has higher priority than Optical auto-sensing when both are enabled.
Usually, it is set to HDMI but the source for the HDMI isn’t on..
@F1 Fan,
If you set the "Standby Mode Source" to "Optical," the input will automatically switch to "Optical" when the Ultra enters standby mode.
However, there is a bug where this does not work when the Ultra enters standby mode via the TV's CEC. 😑
It might be helpful to keep in mind that if you pause the TV, the Ultra will switch to "Optical" after 3 minutes. (Although it might not actually be very useful)
