telecastermds`
- Oct 25, 2022
When I Chromecast Qobuz to my WiiM, I started seeing 16 bit, 44.1khz as max Chromecast quality even though I have my Qobuz app set for 96/24. Is there a setting I messed up?
I don’t see dynamic range optionIf you want to use Chromecast in better quality, first go to Google Home app > Wiim > Settings > Sound and turn on Full Dynamic Range. I see this option on my iPhone. Then you will get maximum Chromecast quality.
Can you screen shot it? I have iPhone and download latest update on google home. The only thing I can adjust is volume control.Some versions of Google Home have this option, others don't. I have it on my iPhone, but it's not visible on my older Android phone. I don't know what it depends on. I turned it on on my iPhone.
Thanks, I have pro and amp and I don’t have that gear on upper right corner.
I uninstalled both apps and still no gear. Strange why I don’t have it.I had the same issue with WiiM Pro while WiiM Pro Plus was fine. So, I asked the forum and the solution is to uninstall iOS WiiM Home App and re-install the app. It worked for me.
I don't have it either on Android. Do they really restrict dynamic range if you don't select that option? Sounds dubious to me.I uninstalled both apps and still no gear. Strange why I don’t have it.
Great find.It seems like Full Dynamic Range only appers when connected using 3.5mm or RCA cable.
When connected through optical cable always uses Full Dynamic Range no matter the switch.
I've been using Chromecast Audio with optical output from the very beginning. I found out about this setting on some forum. It seems to me that the lower quality is the default setting for Chromecast and it should be changed. But maybe Google has changed something? The sound is definitely better after turning it on.It seems like Full Dynamic Range only appers when connected using 3.5mm or RCA cable.
No it doesn’t but if we run same flat form with same version he has it and I don’t. Just curious why some has it others don’t.I don't have it either on Android. Do they really restrict dynamic range if you don't select that option? Sounds dubious to me.
I don't have the cog wheel for settings at all for the WiiM amp but I do for a Google Nest Mini.No it doesn’t but if we run same flat form with same version he has it and I don’t. Just curious why some has it others don’t.
I have two Google account - one for personal and another for my work. I assigned WiiM Pro Plus to Google Home with my personal Google account. I have two iPhone - again one for personal and another for work and sync with respective account. With Google Home app on my personal iPhone, I see a cog wheel and can turn on full dynamic range. I connect WiiM Pro Plus to an external DAC via optical. With Google Home app on my work iPhone, I see a cog wheel but cannot control. It says "Request invite to manage" if I need to use a cog wheel. Hope this helps.If this is confirmed, you need to inform Wiim so that they write about it in the user manual, because almost no one knows about it.
But it's also incomprehensible to me. I have 2 Android devices, 1 iOS, on all of them there is Google Home and Wiim is visible, and only on iOS there is a Full Dynamic Range switch. Maybe it has to be the device of the founder of the Home, and other household members do not have permissions? I don't know what to think. You have to look on Google and Chromecast forums. I have had this function for years, but always only on the main device.
