telecastermds`
Active Member
- Oct 25, 2022
When I Chromecast Qobuz to my WiiM, I started seeing 16 bit, 44.1khz as max Chromecast quality even though I have my Qobuz app set for 96/24. Is there a setting I messed up?
That screen is part of the Google Home app and not everyone has that…
You need to add the device to a Room.I uninstalled both apps and still no gear. Strange why I don’t have it.
It shows now, thanks!You need to add the device to a Room.
I have exactly the same problem. Did you solve it somehow?When I Chromecast Qobuz to my WiiM, I started seeing 16 bit, 44.1khz as max Chromecast quality even though I have my Qobuz app set for 96/24. Is there a setting I messed up?
If you are using an Ultra, that’s all it currently supports on its version of Chromecast. WiiM are working with Google to improve that.I have exactly the same problem. Did you solve it somehow?
Thank you for the reply. I'm using Pro Plus with Optical Out 24/196.If you are using an Ultra, that’s all it currently supports on its version of Chromecast. WiiM are working with Google to improve that.
Ok, I should have read the thread title, sorry just woke upThank you for the reply. I'm using Pro Plus with Optical Out 24/196.
Do you have the mobile & WiFi streaming quality set higher than CD in the Qobuz app settings? I get hi res 96khz on that track, but if I change the streaming quality to CD down from hi res in settings , I get your screenshot.Yes, I'm using Qobuz Android app, latest version.
Here's what it shows in Now Playing.
You’ve fallen down the same hole I did - we’re talking about the pro plus hereHi all,
This is a known issue with Chromecast, which only supports CD-quality streaming when using Qobuz with the WiiM Ultra via Chromecast. We have reported this issue to the Chromecast team, and they are investigating it. We will keep you informed of any updates.
Hi Bunside,You’ve fallen down the same hole I did - we’re talking about the pro plus here![]()
Yeah, as identified by @Brantome earlier in this threadHi Bunside,
We have identified that the issue originates from the Qobuz app. The app consistently displays CD quality (16-bit, 44.1 kHz) on the Chromecast device page, even when the WiiM Pro Plus is playing at 96 kHz. We will report this issue to the Qobuz team and hope for a prompt resolution.
There seems to be a CD version of that as well as a hi res version - try searching for the track again and choosing the hi res version instead. Nit sure why Qobuz would show both versions
Does this Qobuz flaw apply to other WiiM products as well or just to the Pro Plus?Hi Burnside,
All of them, mini apart obviously. I don’t have any other Chromecast target devices to tryDoes this Qobuz flaw apply to other WiiM products as well or just to the Pro Plus?
I cannot comment on Qobuz but why would you want to use Googlecast with Tidal?At the same time, same thing happened with Tildal.
At the same time, i steel can cast through Chromecast, from bubbleupnp to both devices up to 24/192.
So..... i think we have here some problems with standard Chromecast API wich strong used by Qobuz and Tidal dev's and not so strong by bubbleupnp developer, and looks like this API at this time is buggy.
Yes, it does! I can Google Cast Qobuz 24/96 to a Wiim Pro and CA Evo 150.Of did you happen to set up a Chromecast group consisting of the 1120 and the WiiM Pro Plus? In this case, Google does not (and to the best of my knowledge never did) support hi-res.
