*.bak to put instead .flac?
What to change in this file for example?
Just add .bak to the file, so 01. Genetic Walk.mp3.bak*.bak to put instead .flac?
I don't have scan music library in Libreelec,i enter with video library and then browse to folder,i try to scan music library to see if that will fix the problem but it doesn't so i cleaned the music library and i use always with video library to browse to folders.Now i will try to rename the file to see what happens.For the above test I assumed you could browse by folder but there doesn't appear to be one, so I guess you'll need to find the renamed file through album view I guess.
Actually, why don't you try removing the spaces in a filename. If I change my file from "01.01.flac" to "01. 01.flac" then it fails to play. I do see the Green play button but it just seems to skip through them.
Just make them as plain boring ascii with no spaces e.g. abcdefg.flac e.t.c
This is messed up!
There's bound to be nuances to it but I think it's the way Libreelec is encoding the space, it seems to be double encoding, which is why %20 (a space) is going to %25 (a %) plus 20. It may well also be if it's only after a dot, but then where do you stop looking, we've already got an example for them to look at, hopefully they won't just fix it for files that look like NN. NN.flacI'd be quite surprised it the wiim couldn't handle spaces in a file name. Many, many songs have more than one word titles!
Maybe it's having a space after a .
The example filename above was
What about trying
01 Genetic Walk.mp3
Sure, I was just thinking that a bulk rename to remove dots from within filenames would be easy and still leave readable file names.There's bound to be nuances to it but I think it's the way Libreelec is encoding the space, it seems to be double encoding, which is why %20 (a space) is going to %25 (a %) plus 20. It may well also be if it's only after a dot, but then where do you stop looking, we've already got an example for them to look at, hopefully they won't just fix it for files that look like NN. NN.flac
Other servers obsfucate the actual filename. AssetUPnP for example has a hash like string which seems to work for everything so wouldn't have this problem, MinimServer uses *20, others probably correctly use %20 e.t.c.
If feels such a cop out thoughSure, I was just thinking that a bulk rename to remove dots from within filenames would be easy and still leave readable file names.
I've just retested and I think it is all spaces, not sure what I tested above when I said it worked with a space as long as it wasn't after a period, probably got the wrong ssh window as flipping between KODI, LibreELEC, WiiM and BubbleUPnP.I tested now with lot of combination but in my case work just if i remove the spaces,no space no problem,i check a lot of albums to find a song with no spaces,and i found couple songs with numbers and dots with only one name but with no spaces, and play only that song from all album with no problem. Defenetly space is problem with my server.
Hahahahah...At least now you know though, and it only took you 5 years![]()
It was similar but much more convoluted. If there's a dot in the filename (in addition to the dot before the file extension) and there are fewer than 4 characters between it and the final dot then WiiM fails with a MIME type error, UNLESS there's a space in those characters then it's fine! And only through a third party app as through the WiiM app it was fine!In another thread someone else discovered that WiiM can’t deal with file names containing a dot and space.
