Brantome
- Oct 20, 2022
@Brantome , given you seem to have a hotline to @WiiM Support it might be worth you replicating the bug they introduced in the WHA a couple of releases ago.
If an album has disc subtitles MinimServer displays that title in the track listing (some control points can use it to play a subset of tracks from an album), and the existence of this in the xml causes the WHA to crash.
I think this functionality is only available with a MinimServer license, if you have one the easiest way to replicate it (without having to modify tags) is by setting 'serverOptions: showAllDiscs=true', this tells MinimServer to label each disc for multi-disc albums. After a restart, simply browse to a multi-disc album and you should see it crash. I'm hoping that if you subsequently send feedback it'll include any crash dumps.
If you don't have a MinimServer license then I guess we'll wait to see what happens once they fix the track ordering problem again, as this may go away at that point.
Thanks
Well, if submitting a fair number of tickets gets you a hotline, then that must be it
I’ve had a Minimserver/Minimstreamer licence for a long time, so I’ll give it a go, although might it depend on how I’ve previously ripped the discs? I’ll need to have a look at some multi disc albums and see what sort of structure they are, whether it’s just separate folders or having tags of the type 1/2, 2/2 etc.
I’ll try and have a bash at it sometime today
