I'd beI’ve got it on my WiiM Mini and unfortunately it still doesn’t work using BubbleUPNP playing my R.E.M. tracks
I’ll submit a ticket…
Hi Brantome,I’ve got it on my WiiM Mini and unfortunately it still doesn’t work using BubbleUPNP playing my R.E.M. tracks
I don't have Kodi (I do have an aversion to it given its often nefarious useHi Brantome,
Our engineers are looking at your log. Meanwhile, can you try the KODI instead of MinimServer? I appreciate your help!
Hi Brantome,I don't have Kodi (I do have an aversion to it given its often nefarious use), but I'll see if I can set up an instance and try it...
Quickly installed Kodi on my PC pointing to the same folder as Minimserver and still getting the Invalid Mime Type error when using BubbleUPNP to WiiM with file names of the type nn - name - R.E.M..flac (note the double period before 'flac') . Ticket number #10954 raised. Cheers...Hi Brantome,
Don't worry if you don't have one. Thank you!
KODI is fine, it's just the dodgy addons you need to steer clear of.I don't have Kodi (I do have an aversion to it given its often nefarious use), but I'll see if I can set up an instance and try it...
Yeah, my experience of it is a bit jaundiced I admit given I tend to see it raising its head on fire tv and related forums where I'd bet a lot of use is down to the dodgy addons. And it's years since I used Sandboxie - good to see it's still goingKODI is fine, it's just the dodgy addons you need to steer clear of.
I use Sandboxie Plus (a lightweight software sandbox) so I can install all the software I want without affecting my main windows install.
Since Sophos made it open source, Sandboxie Plus has gone from strength to strength under its new developer.And it's years since I used Sandboxie - good to see it's still going
Hi ,I,m not on beta, it's not problem to test everything but I'm ar work now and when i will be home i will try to rename the file and rescan and try with Bubbleupnp.That's great news.
I haven't had the update yet (is there any way to know you're in the beta program?) so is there any chance you could test with a file that has a period in the last 3 characters of its filename? I don't know how your files are tagged, but just adding 'ab.cd' before the file extention (filename1ab.cd.flac) then rescanning should be enough.
EDIT: Forgot to mention it would need to be with an external control point (BubbleUPnP e.t.c.) as the WHA already works. If it's too much trouble don't worry.
Thanks for the offer viktor but @Brantome installed KODI and tested it for me so we know it's still a problem (as expected).Hi ,I,m not on beta, it's not problem to test everything but I'm ar work now and when i will be home i will try to rename the file and rescan and try with Bubbleupnp.
Hi Simbun, Brantome,Thanks for the offer viktor but @Brantome installed KODI and tested it for me so we know it's still a problem (as expected).
Whether it affects you depends on your naming conventions really, for me nothing works as I name my files %discnumber%.%tracknumber% but if I'd used %tracknumber% - %title% it would have affected ~100 tracks.
Well, I really doubt itI hope we fixed all the remaining UPnP-related issues.
Will see. We like to take this challenge.Well, I really doubt it![]()
What about gapless playback issues? Do we count them as a part of this challenge?Will see. We like to take this challenge.
I would love to help but I'm still stuck on firmware 4.8.512355 (20230330).Hi Simbun, Brantome,
Based on our tests, we have fixed the "." on the file name that caused the MIME type error before in our latest firmware. Can you please help try and see if it works for you? I hope we fixed all the remaining UPnP-related issues. Thank you!
...and multi-disc track ordering and the fact that disc subtitles (from MinimServer) crash the WiiM Home app (unless these have been fixed in the firmware update I'm yet to receive).What about gapless playback issues? Do we count them as a part of this challenge?
Unfortunately not fixed for me using Minimserver and Bubblecast sending to my Pro on firmware 4.4.515159— same mimetype/ file not found error.Hi Simbun, Brantome,
@Brantome , given you seem to have a hotline to @WiiM Support it might be worth you replicating the bug they introduced in the WHA a couple of releases ago.Unfortunately not fixed for me using Minimserver and Bubblecast sending to my Pro on firmware 4.4.515159— same mimetype/ file not found error.
