@WiiM Support, @WiiM Team can you provide us the status on room correction and usb output? Thanks!
Upvote
1
How boringpeople capable of carrying out before and after measurements in a "solid" manner and experienced in the exercise are certainly to be prioritized.. it seems to me ;-)
Rules everybody out bar @onlyonemepeople capable of carrying out before and after measurements in a "solid" manner and experienced in the exercise are certainly to be prioritized.. it seems to me ;-)
While others might usefully comment on the process itself - after all, it wouldn’t necessarily gain plaudits if it showed textbook graphs but was an absolute pig to useHow boring
All we need is someone to say they applied it, and it sounded better!
Isn't that how hifi tweaks work?
No worries, I won't compete hereRules everybody out bar @onlyoneme![]()
I haven’t seen you commenting here in a while glad to see you.No worries, I won't compete hereI didn't even finish my Amp test yet...
Unfortunately other priorities in my life. But I'll try to become more active here, pretty sure it won't make everybody happyI haven’t seen you commenting here in a while glad to see you.
No plan to participate in this beta, sorry. It requires a lot of work to analyze effects in the digital domain, to compare with direct umik measurements and REW suggestions, etc. I can't handle it now.I hope you will try the room correction beta so you can give us feedback on what’s work and if there’s bug need to be fixed. Many of us users are into this room correction hoping it will take our enjoyment listening to new height.
While others might usefully comment on the process itself - after all, it wouldn’t necessarily gain plaudits if it showed textbook graphs but was an absolute pig to use![]()
Do you think you can do that with two WiiMs?as a quick reminder if a separate left and right peq would be welcome..
the rc mode making the mesureaments and corrections separately on the two channels could be welcome.... ;-)
Yes, but if the two WiiMs are perfectly synchronized, it seems easier and more reasonable than doing it with a single WiiM.I foresee all sorts of unforeseeable problems.
I don't understand how or why....Yes, but if the two WiiMs are perfectly synchronized, it seems easier and more reasonable than doing it with a single WiiM.
I don't understand how...
