slartibartfast
- Apr 18, 2024
I only correct up to 500Hz so probably not. I am sure it would sound different though.If you turn off all the boost frequency, would it sound dull?
Yes 20 to 20khz.
I just followed what rccarguy to see how it sound. I will just going to enable them back. I don’t think it’s a problem for halo jc 1 knowing it’s one of the most powerful and expensive amp that ever made. It can drive any speakers known to man down to 1 ohms.
With all 10 bands enable, sound was great than rc off. I think rc have gone a lot of under the hood improvements. I like soundstage that is large as monument. In some occasion, I use Yamaha dsp to give the soundstage as large as palace at 360 since it uses 4 speakers to simulate dsp while the main just produce direct sound. It uses 6 speakers. Main speakers produce direct sound while the other 4 a combination of early reflection and reverberation. I’m one of the very few who like dsp but mostly users stick to straight mode.
I will limit to those range. Thanks!Generally it's best to do <400hz that's where the room effects the sound the most.
Try also 4khz, that what Anthem ARC uses.
less is more when it comes to RC you don't want to be aggressive.
Here is full range sweep of my towers, you can see where you want RC to concentrate on.
Majority doesn’t like how dsp sound and your right the reverb and echo is not something most listeners want.From my experience Yamaha DSP is crap (I have a Yamaha AVR) the stock DSU/DTS decoders are fine, but it's the extra gimmicky DSP modes which are rubbish. Too much reverb and it makes it feel you're listening in a bathroom or nightclub
If you have a chance checkout Lexicon Logic 7 music surround with old Lexicon processors, those were brilliant. It expands the music in such a way it's subtle. Can also adjust the front/rear mix, and the surround roll off etc, you might not want the rears to be full range, so you can adjust it to say 12khz. You can adjust the amount of center mix, my preference is most goes the L/R with only a bit to the center, so it's like halfway between 5.1 and 4.1 phantom mode.
Small speakers like that are not meant to drive them or feed them on insane level of power. What they need a separate subwoofer to make them sound full. Tower speakers with multiple array of 7 inch could handle a load and can go deeper. Preferable 4 drivers of 7 inches.One thing you DON'T want to do is boost below the F3 point of the speaker, ie if you try and boost 20hz-80hz on Kef LS50 (and running full range also) you'll blow the woofers out
Why does AV receiver it’s nearing to zero volume and barely loud? Unlike wiim ultra just few click it can frighten the wildlife.One thing you DON'T want to do is boost below the F3 point of the speaker, ie if you try and boost 20hz-80hz on Kef LS50 (and running full range also) you'll blow the woofers out
Huh?Why does AV receiver it’s nearing to zero volume and barely loud? Unlike wiim ultra just few click it can frighten the wildli
I connect the Yamaha AVR pre out to external amp rated 450 watt at 8 ohms and 850 watt at 4 ohms. When I listen to John Lennon imagine it’s just barely loud. However, wiim ultra on same external amp it would blow the woofer on my power hungry Polk legend. Is Yamaha pre out putting out low voltage?Huh?
You mean the calibration tones? Make sure it's not that loud you can damage speakers during the sweep.
I use fixed level to my pre amps . I don't use variable
(sorry not the ultra but...the amp in 2023)It was suggested from the first days of the arrival of the ultra and the sub function
classically... orders and types
I have successfully used per speaker room configuration, I am presently in a higher seat having had a hip replacement, I didn't want to rerun Dirac room configuration (5.1.2) as I have it as I want it, so it was a good excuse to try out the Wiim room correction, stereo only obviously, got to say I'm impressed, certainly for a free addon, I cannot compare to Dirac directly as it sounds different at a different height.
Another great reason to buy the Wiim Ultra.
@gazza1101 didn't say otherwise, did he?You can actually try it for each channel since a couple of months back.
@gazza1101 didn't say otherwise, did he?He just had no need to try it until recently.
I assume the "stereo only obviously" war rather in contrast to "rerun Dirac room configuration (5.1.2)".I thought "stereo only obviously" was a way of saying "since that is the only option right now", but maybe I misunderstood.
