alpha_zulu
Senior Member
Or wether he really needs it …Not sure if it worked fine at your place, as you barely could hear it…
Are you applying the Room Correction to the input you are listening to?Hello everyone! I was really excited to see my wiim pro plus now has room correction. However, it is not audible at all. Did anyone experience the same?
Everything seems to work fine: I hear the sound it makes when calibrating, I hold the I-phone on the indicated position, it shows a graph and the list of the EQ corrections it performs... but no difference whatsoever (I have tried many times, even AB test with eyes closed and my finger activating and desactivating the filter on the app)
Obviously I am doing sth wrong but can't seem to figure out what it may be... any ideas?
Thank you so much in advance!
Just select the input on the PEQ page. Being an Android user I don't know if Room Correction is different.I have been searching for a way to apply room correction to a specific input but could not find it.
I had always assumed that any correction with EQ would affect sound as long as the wiim pro plus was playing
I had always assumed that any correction with EQ would affect sound as long as the wiim pro plus was playing (like for instance if I turn down one of the sliders on the graphic EQ it is audible almost immediately, without having to specify which input I want to apply it to)
Yes, it is onAnother thing: is the room correction swich „on“?
If You enter RC screen at the top right the config wheel…
I found three different options for the curve: B&K, Harman and Flat (so far I have used B&K since it seems to be the default one)
Hi jheflin10, TeamAnyone know when this will be available for android users?
I see a spike in group delay of nearly 80ms. Where does 0.4ms come from?I have lately with last version of app and firmware run another correction with B&K and no restriction in the q or gain . I have entered the setting in rew and showed me that I need 2.67db of headroom . So the volume of 95% was covering it.
Now I run HouseCurve after Wiim room correction and it confirms the curve using again the iPhone mic.
I see a spike in group delay though and I don’t know if it is related the peq . Not talking about the lowest frequencies my speakers do not produce any usable output , I am referring around 80 and 125hz . To be honest these spike is 0.4 ms so not so high and what I hear seems very correct . So there is that if as a next step you can utilize fir/iir corrections
Give me a clueThat is normal for such low frequencies which the speaker cannot produce properly without roll off . Can’t you see where it is 0.4?
