Roomfit control in smart presets
mbonadio
Is it possible to get the option to default roomfit on or off in presets - apparently the ultra has this feature (as announced in a recent firmware update) - but not my pro plus and my WiiM
amp.
It is annoying to go in and disable and enable it every time I use headphones!
I basically just leave it off now and use EQ only settings to tune my speakers and headphone because at least that option exists - but that is unfortunate - roomfit is a key feature to me! I am not upgrading to an ultra either - not until you fix Apple Music connectivity!
So I got home and ch Erebus wha to have to report
#1 - I am a dummy - save button has indeed been there. I used it just now, and I named it and it magic - shows up at bottom for selection and in smart presets. Flog me if desired. I missed this connection in my head!
#2 - This solved half my problem. To solve the original ask for roomfit, I put new knowledge to work. I printed my room fit profile, disabled it, and then entered it into PEQ. I saved it and in smart presets I created 2 - one for speakers using this profile and one for my headphones using a different one. Now I can more easily switch between listening modes.
I repeated this on both WiiM devices.
This solves my problem. Would I like a way to export roomfit to peq, Yes I would. But it took me all but 5 minutes to print and enter the info manually.
Appreciate the input- you all helped me! Now I know a lot more about wiim’s capabilities and can get started on creating a desired peq profile for my headphones! :-)
Glad it solved your issue but it doesn't solve the general issue. When you move the RoomFit profiles to the PEQ you cannot change your EQ on top of that.
I have a fixed RoomFit profile for the main output (optical) and then I apply EQ depending on music style and volume.
If I want to change to another output (USB) the RoomFit profile no longer match and I need to go into the RoomFit menu and change it.
I think the best solution to this would be to associate a different RoomFit profile to each output, just as we already have different EQ and volume associated to each input.
