If you haven’t had the firmware update you won’t see anything if you just removed the bridge.
If the bridge is up and running correctly AND you have had the firmware you will see 2 instances of your Pro / Pro Plus in LMS. They have different icons in Material.
If you then stop the bridge or uninstall it you’ll drop to the one Squeezelite version.
There is nothing you then MUST do but good practice might be to set the player settings in LMS to 100% and any other tweaks you want.
