Strange sound problems with Wiim Pro Plus
MSdt
Today as usual I started to listen to music but the sound was harsh and unpleasant. It happens sometimes for unknown reason for me. In most cases restarting the device (Wiim) do the trick, but not today. After restarting WiiM the sound was not better, so I tried to check if this is EQ (PEQ) or RoomFit problem. PEQ was enabled and RoomFit was disabled exactly as they should be (few days ago I did RoomFit correction and copied some settings to PEQ, disabling RoomFit after that). I tried to check if after disabling/re-enabling PEQ I will hear any difference, but there was no significant (or no) difference. So I enabled RoomFit than disabled it and enabled PEQ again and the difference was significant and sound was back to normal.
Is it possible that Wiim Pro Plus does not apply EQ (PEQ) settings on start (or restart) sometimes? My WiiM device is always on, I do not switch it off. I wonder what can be a reason that one day everything is ok and when I start to listen to my music the day after the sound is not ok.
This may be related to the issues occurring here.
Please submit a ticket via the feedback section of the WiiM app.
(WiiM app -> More -> Feedback)
Your device logs are sent to help resolve issues.
