Asr is not an authority. They are measurement biased freaks. Experience first. Measurements are a tool, not an end.Here we go again power supply lps vs switching supply. ASR said no difference but users with different hearing said there was difference. Hearing translate by brain vs measurements. Measurements first.
It is a very old trick to misrepresent my argument. I said measurement was a tool, not that it does not matter.If a PSU provides unstable voltage, not enought current, high noise, deviations in the supply, and chucks noise back on the circuit this can be measured and tested for. In far more repeatable, accurate method without user bias. The results are able to be printed out, and others are able to peer review test them also.
You listening to it will none of those, it would be like "this £2000 fuse in the plug made it sound much better after I spent my hard earned money on this, so it must do something"
There two types of people based on asr straight measurements or subjective from other reviewer like cheap audioman or Andrew Robinson just to name a few.Asr is not an authority. They are measurement biased freaks. Experience first. Measurements are a tool, not an end.
Yes, you're right.When an audio designer or speaker for that matter, they all use computer modeling and when produce they measure them. All these measurements devices serve them as their building block. Now, it may have measured well but the question will every ear like super clean, neutral and polite sound? I’m one of them doesn’t like neutral and polite sound and like my sound to be spice on certain frequency to be boost and that’s where eq in wiim I used. Everyone has its own preference and there is no right or wrong to be criticized by others. Everyone knows tube amp has high distortion yet I like how tube sounds. Let your ear be the final judgement.
I don't think that proves the difference in sound quality between a "cleaner lower-cost PSU" and a "more expensive and more cleaner PSU".I can attest that the PSU can make a huge difference. It did with my Chromecast audios, unexpectedly. But I wasn't buying audiophile PSUs.
4 years ago, wanting fewer wall warts and better cable organization, I tried connecting two sets of 6 CCAs each to a 6-port USB charging station made by Amazon under the AmazonBasics brand, and no longer available for sale, but my order history shows each station cost $27.99.
There was horrible hiss and ground loop noise in some of the CCAs, which I could never resolve, except by switching back to 6 individual USB power supplies.
Maybe an electrical engineer can explain to me why this happened ?
I still have those two 6-port charging stations. Maybe I'll try them with the WiiM Pro Plus also after I replace those 12 CCAs with 12 Wim Pro Plus (1 done, 11 to go).
No, it doesn't prove more expensive PSUs could be better. There are usually diminishing returns, and the audio quality probably plateaus at some level.I don't think that proves the difference in sound quality between a "cleaner lower-cost PSU" and a "more expensive and more cleaner PSU".
It is conceivable that a power supply of extremely poor quality, such as the USB of a PC, may degrade the sound quality.
Yes. The case you posted was probably not caused by the PSU, but by connecting multiple devices to one PSU. Although I can't explain its cause.No, it doesn't prove more expensive PSUs could be better. There are usually diminishing returns, and the audio quality probably plateaus at some level.
My experiment shows what can happen with a low-quality PSU though - it can definitely make the audio worse.
I personally think the PSU that came with the WiiM Pro Plus is fine. I doubt I could hear the difference between two PSUs other than when one is obviously faulty.
