wiimamp user
- Jan 12, 2024
Thanks this works
Thanks this works
My Apple apps have also been updated today, and reflect today’s changes, with Max now available, and the Current subscriptions has now changed from HIFI to TIDAL.My Android App was updated last on 08.04.2024 to 2.9.1.2408408
and the iOS app today early morning to 2.9.1.24040110
and both offer "max", but show still HiFi Plus
Was that a typo and should read 2.9.1.240408?My Android App was updated last on 08.04.2024 to 2.9.1.2408408
But i think can hear a difference..But please stay so excited for your amp, even if you can not really hear a difference between hires and CD quality ;-))
I don't even care ... for the moment, at least.But i think can hear a difference..
Or is it the placebo effect
I can hear it..(my opinion.)![]()
Does this also stop you using "max" from the tidal app when streaming to the WiiM?My Apple apps have also been updated today, and reflect today’s changes, with Max now available, and the Current subscriptions has now changed from HIFI to TIDAL.
The WiiM home app has not changed, and still shows Subscription as HIFI.
There’s currently no way to select Max, so perhaps the WiiM app needs an update to resolve the issue.
I can use Tidal Connect to my WiiM devices to access the Tidal Max Flac content.Does this also stop you using "max" from the tidal app when streaming to the WiiM?
The music that I’m listening was Madonna and still mqa.
So can you confirm that your Tidal Account Subscription hasn’t changed from HIFI Plus to TIDAL in the WiiM app.I logged in and out a few times (for curiosity only) alarmed by the trumpets of Jericho here ;-)
No problems, the WiiM app shows still HiFi Plus and everything works as usual.
There will still be MQA albums in their catalog as some record labels only produce that (2L is one iirc). Even Amazon and Qobuz have MQA albums as a result but ignore the MQA info.As it will be forever, I bet ;-)
Since you mention it yourself ...OK it's an useless thing but it's nice to know also...
Absolutely not, since generally is the only available...Would it keep you from listening if you knew the exact bitrate in advance?
What... you mean you can't tell just by listening....Where can you see the bitrate using Tidal connect?
I can see the max Files ( could see them before april 10th also) .
But where can you see the bitrate or if you are playing hi res Albums?
This depends on your ears, and indeed your equipment, on some people's speakers you can't hear the difference between Spotify and Hi-res...What... you mean you can't tell just by listening....
You mean you think they might be misleading you by simply providing an upsampled version?How does this work with the high res Files..
If it's an older Album and it's high res..
Is this a SACD?
Is it recorded in high res in the first place?
When i was asking i did listened later on the amp.
I did hear a difference ( my opinion)![]()
