USB Hub not working
johnzena
I've read from other posts that you can use the usb as an input and output simultaneously. That is to send the audio to an external DAC and read a usb dive at the same time. It's not working for me using a usb hub. I'm using the extent brand. Is it not functional or am I using the wrong brand and if I am can someone tell me which one I should use? Make and model please.
Yes, a 1TB Sandisk Extreme portable SSD and feeding my Linn MDSM/4 amp over USB. Can even play tracks from that SSD to the amp/DAC at the same time.
Just in case anybody wants to know I couldn't get the usb hub to read files and play them back via usb to the dac. I could read the files from the usb but had to choose the output as coax or optical. Doesn't really matter because the Ultra will convert all dsd/dsf files to 24/192 pcm anyway. It does an exceptionally good job. I was listening to psaudio/octave records dsd256 files.
