LennyBruce
- Aug 20, 2024
Tried it. No joy.
Thanks for the suggestion though.
It just doesn't see the USB drive.Try deleting cache and force close the app.
What kind of files are not detected?
Did you try transfer those files to another HDD to see if they are being detected there?
Just copy or transfer those files to another HDD/ USB stick and see what happens..
Whatever we propose here is just guess work. I would probably remove all partitions.from that SSD and create a new one, formatting it with either exFAT or NTFS. But I don't know what's going wrong when you connect that drive.It just doesn't see the USB drive.
It works with a 2.5" HDD with no external power supply but won't work with either a SSD or a 3.5" HDD with a external power supply.
If you plug the SSD with the same cable into another music player does that recognise it. If you don’t have a DAP maybe your car?It just doesn't see the USB drive.
The Samsung T7 are great but I think minimum is 1tb.Well after the firmware update, it still doesn't work.
It's Netac SSD. I'll send it back to Amazon.
Can anyone recommend a 500gb SSD or USB stick that definitely works with the Ultra?
Maybe Sandisk usb stick? Reliable brand I assumeWell after the firmware update, it still doesn't work.
