I’m talking about the separate BBC app, rather than the one in vTuner. Nothing in vTuner is working for me at the moment.vTuner is working just fine for me. Though it doesn't work with BBC stations.
Try using WiiM's Open Network Stream function.Recently, I've become very reliant on v-tuner channels, but some channels that used to play (WPFW) no longer play. Other new channels that I've successfully searched for and added to Favorites (KVRU) won't play.
Both stations mentioned above have live streams on their respective web sites that are operational, as well as functional channel streams on the V-tuner web site, but to listen to them I must switch from Wifi input to Bluetooth cast from my Android device, but in doing so I lose the ability to easily change to another favorite preset.
Adding to that hassle, the Wiim remote pairing often gets messed up in the Bluetooth flip flop and takes several failed re-pair attempts before working properly again. Very frustrating. Hope there's a fix coming. Thanks
I used the Developer Tools menu item in Google Chrome.Thanks! Those worked. I was able to add both to Favorites. Can I ask how you found the links?![]()
softlabbd.com
The streams you found are the same as the ones from Radio.NetI used the Developer Tools menu item in Google Chrome.
You'll find instructions here in the How to Find Radio Stream URLs Globally? section:
How to Find Online Radio Stream URLs for ShoutCast, Icecast
Finding online radio station URLs can be sometime challenging. This guide will help you finding most popular radio station URLs in a matter of timesoftlabbd.com
Doublej thanks so much! I couldn't manage the process on my Android tab, but on PC was able to stumble through using Brave.I used the Developer Tools menu item in Google Chrome.
