Matias
So your "serious software really not within the skills of wiim" comment was just intentionally coarse for nothing. Thanks, but keep it next time.no....
you I am, supporting wiim since 02/22...so I think I have a certain perspective on the qualities, practical skills, of wiim....So your "serious software really not within the skills of wiim" comment was just intentionally coarse for nothing. Thanks, but keep it next time.
Ok. Why do you then use their products and stick around here if you have such a low opinion of their abilities? Even if they didn’t have those skills in house, who’s to say they wouldn’t insource them? Or re the microphone, use a “qualitative” external microphone, suitable connected to the Pro’s line in?no....
have you already carried out acoustic measurements, room corrections, used powerful software such as rew rephase etc??Ok. Why do you then use their products and stick around here if you have such a low opinion of their abilities? Even if they didn’t have those skills in house, who’s to say they wouldn’t insource them? Or re the microphone, use a “qualitative” external microphone, suitable connected to the Pro’s line in?
That’s a very blunt, if not insulting assertion.
I don’t see the relevance of that personal question.have you already carried out acoustic measurements, room corrections, used powerful software such as rew rephase etc??
let's help wiim to already realize their promises as a qualitative "10-band" peq modeI don’t see the relevance of that personal question.
dynamic loudness isn't so tough. You could also just create an adjustable loudness contour with a slider in the app. If the EQ is there, the possibility is there. Tough part is, perhaps, that the stream may have to be interrupted to implement the new contour....and may be something with a Hayabusa Supercharger? In dark blue? And with side-pipes! And most important: Not more than 400 €.![]()
Same. Keep it simple. Keep it inexpensive. Keep up with the product updates. We’ll keep spreading the good word about Wiim.I'm likely an outlier on this - I don't want anything more from WiiM, other than what the Pro currently delivers. I replaced a Bluesound Node 2 with my Wiim Pro, and now I pretty much just want it to work and forget about it. It do hope that the automatic firmware updates are thoroughly tested before being pushed out, because for the most part, I just want the device to behave correctly like it does now. I'm using it only for Qobuz and Spotify streaming device to a very capable external DAC and downstream component stack (Benchmark), and the rare Chromecast or AirPlay use. I don't need any equalizer functionality, or really, anything other than what the WiiM Pro does now. As long as it continues to work well, and doesn't mess with the bit stream, I'm happy.
Wiim mini & PRO:What products would you like to see based on what you've experienced so far?
- The next level of the Pro Plus with aluminum case, HDMI in/out, a volume knob. Maybe a built-in linear power supply. Output menus and song info to a tv would be nice too. I would upgrade today.What products would you like to see based on what you've experienced so far?
I’d imagine the price for bespoke builds like that would go thru the roof…My request is simple. Offer a Wiim Pro without DAC, with subwoofer out, 12v trigger, coax and Toslink out, gigabit Ethernet and WiFi 6e.
Better yet, give the buyers the option to pick what they want, order it, with a waiting period of 60 days.
I'm struggling to see how a subwoofer out fits with no DA conversion. A digital sub, with a standalone LP filter??My request is simple. Offer a Wiim Pro without DAC, with subwoofer out, 12v trigger, coax and Toslink out, gigabit Ethernet and WiFi 6e.
Yes, and I am struggling to see the need for Gigabit Ethernet to stream music!I'm struggling to see how a subwoofer out fits with no DA conversion. A digital sub, with a standalone LP filter??
WiFi 6E can use the 6GHz band, which may provide more stable connectivity.Yes, and I am struggling to see the need for Gigabit Ethernet to stream music!
