A suggestion to use another app when there’s currently what you see as a deficiency in the WiiM app is a very helpful response in my book…Funny though... I asked 2 questions on this forum: with my first one the answer I got was "use another app"
I had the same issue with a Berhinger ECC 8000 measurement microphone -- worked fine with my laptop but not my phone. Buying an inexpensive Dayton IMM-6C solved that problem and gave better room correction results than my phone's built-in mic.I have a flat mic, good quality, but I never managed to make it work with my phone: it's not being recognised
Or a mic with a pre-amp that could use RCA inThere is a USB port though and many of the measurement mic’s actually use USB so not that bad of an idé.
I totally get your point, and I know this suggestion was given to try and help me, but here's my point, and I'm honestly curious about this point: if I use a different DAC (which I do) and a different app, what's left to enjoy in the Wiim Ultra?A suggestion to use another app when there’s currently what you see as a deficiency in the WiiM app is a very helpful response in my book…
For me the enjoyment comes from being able to listen to music in the simplest, most convenient way with the functionlity I desire.I totally get your point, and I know this suggestion was given to try and help me, but here's my point, and I'm honestly curious about this point: if I use a different DAC (which I do) and a different app, what's left to enjoy in the Wiim Ultra?
100% agree with this...For me the enjoyment comes from being able to listen to music in the simplest, most convenient way with the functionlity I desire.
If a particular app's shortcomings prevent that then I look for something else that can achieve this.
Personally, I have a negative correlation between using the wiim app (to play music) and enjoying the ultra, or any other wiim, because of things like its queue mangement and not showing a favourite indication on the main now playing screen.
These things quite possibly don't bother others at all, but they do me.
Once I've used the wiim app to set up a few things I can choose between the wiim app (least likely), presets from the remote, bubbleupnp, spotify connect (well, you don't get a choice there!), tidal connect, LMS, chromecast etc.
The wiim app becomes mostly redundant to me at that point, and I was suggesting that if its queue management bothered you as much as it seems then maybe it could for you too.
Of course, that doesn't mean we should let Wiim off the hook and not fix these usability issues.
After all, it was quite some time ago that they acknowledged their desire / ability to be as good as bubble.
(Paraphrasing there, but that's the gist of it, although I also concede they may not have specifically been thinking of things like its queue mangement, just its dnla/upnp capabilities.)
I have just added a Pro+ and connected Minidisk and Cassette tape player with both in and out (optical and analog).I'd like to see a Wiim HUB.
So that those of us with multiple legacy line level devices, via an ADC, could integrate these devices into the Wiim Ecosystem.
3 or 4 pairs of RCAs would allow the connection of R2Rs, Minidisc, higher quality standalone phonostages, CDPs without digital outs etc.
Yes the Ultra has MM/MC capability + line in but, from general Internet chatter, the Phono section is pretty low rent, (MC especially) and whilst okay for budget tts, it's not really good enough for the Rega 3 and upwards users.
Why. Make no sense.@WiiM Team Please consider an Ultra + with balanced outputs … please, please, please![]()
Sure it does if you only have balanced inputs to your preamp and do not want to use a converter. Not everyone has same use case.Why. Make no sense.
So it is not balanced signal you want, just the jacks?Sure it does if you only have balanced inputs to your preamp and do not want to use a converter. Not everyone has same use case.
Why. Make no sense.
A cheaper WiiM mini that has Chromecast, has stable Wi-Fi so that you can connect more speakers throughout the house. A replacement for the older Google Chromecast audio, but with the WiiM software platform. Also, more inclusion for more streaming services. I'm guessing Apple music will never happen, but others like DI FM and sister apps like Radio Tunes, Jazz Radio, Rock Radio, and Classical Radio. Sirius XM and YouTube radio would be nice as well.What products would you like to see based on what you've experienced so far?
