wifi connectivity problems
twd000
I'm having trouble getting my Wiim Amp setup and maintaining wifi connectivity. My home wifi has a router in the basement broadcasting one SSID, plus wired access point providing a different SSID. My iPhone seems to handoff fine between the two networks based on where I'm roaming.
But the WiiM Home app is constantly telling me "device not found" when I return to it the next day. Prompts me to hard reset and go into setup mode all over again.
Does my iPhone need to be on the same SSID as the Wiim Amp to use Airplay?
I have a second Wiim Amp in the basement, wired to ethernet. Should I expect the wifi-connected Amp and ethernet-connected Amp to show up in the Airplay options in Wiim Home app?
