WiiM Amp Pro Firmware v5.2.726630 Update - Aug 18, 2025
Please review the WiiM Amp Pro update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
5.2.726630 (In Progress)
Release date:
8 / 18 / 2025
What's New:
  1. Room Correction & EQ Integration: Room Correction and EQ now work together to provide an optimized listening experience. Learn More
  2. Stabilized Wi-Fi Connection: Enhanced connection reliability, especially for mesh network environments.
  3. Amazon Music: Bitrate information is now displayed when streaming Amazon Music Prime.
  4. Sub Pro Intergartion: Improved pairing experience and overall functionality when using the Sub Pro.
  5. YouTube Music: Native, seamless streaming support. (requires the upcoming app version 3.3.1).
  6. Soundtrack SDK Upgrade: Under-the-hood improvements for a smoother, more consistent listening experience.
Bug Fixes:
  1. Alarm Fixes:
    • Resolved an issue where weekly alarms occasionally failed to trigger.
    • Fixed a bug where only the default tone played for Pandora alarm.
  2. Dolby Audio Fixes:
    • Fixed no-sound issues when playing Dolby audio in multiroom setups.
    • Corrected volume balance behavior for Dolby audio.
    • Corrected low volume when playing Dolby Digital content.
  3. USB Output Fixes:
    • Resolved no-sound issues after reconnecting a USB DAC device when using Google Cast, TIDAL Connect, Spotify Connect, or Qobuz Connect.
    • Fixed audio stuttering when playing at 44.1kHz or 48kHz sample rates.
  4. Playing Status: Corrected the playback status indicator when no music is playing.
  5. Qobuz: Now displays the correct artist name in the app during playback.
  6. Bluetooth Output: Fixed a no-audio issue after switching outputs.
  7. NAS & USB Playback: Playback now correctly restarts from the beginning after the last track finishes.
  8. Playback Speed: Resolved rare cases where songs played at accelerated speed.
Flat: To me is brightest,most open,clear and lacks bass adjusts 48hz to 4khz (suggestion a little more bass) Reamne it to flat or clear ?
Might sound clearer do to not having alot of bass 4 khz up not adjusted
Harman: Very fullbodied (bass) adjusts down to 40hz and max is 3.3 khz (suggestion a little less bass) reaname it to bass ?
B&K: It does something to the midrange a little louder,fuller not bright despite enhancing 17khz alot (i guess i can't hear that high), despite that, flat sounds brighter,clearer,more open, B&K has a little more bass then flat, adjust 73-17.1khz Yamaha ns-10 midrange setting ? Rename it to yamaha ns-10 ?
Flat and harman is what i would use and adjust in the eq if i need to
Just remember that your listening impressions are impacted by the anechoic response of your specific loudspeakers being modified in mid and high frequencies, since you are running RoomFit full-range (something I wouldn't recommend in the vast majority of cases).
This means that other people using different loudspeakers in different rooms with different RoomFit settings might also have different impressions when using the same targets.
They don't adjust all the way from 20 to 20khz Flat it only does adjustments from 48hz to 4khz
Picking the target curve is one step.
Choosing the frequency range in which RoomFit will try to follow the target curve is a separate setting. The lower limit and the higher limit can be set independently. RoomFit will still apply some amount of intelligence and not waste peak filters on irrelevant frequencies.
The intention of room correction (done right) is not to adjust the sound to some fixed target. It aims at removing disturbances due to certain room effects without disturbing the general sound.
