WiiM Ultra Firmware v5.2.813259 - Apr 8, 2026
5.2.813259 (In Progress)
Release date:
Apr 8, 2026
Highlights:
  1. Sub & Main Speaker Sync: Automatically aligns subwoofer and main speakers for improved timing at the listening position.
  2. Per-Input Screen Control: Enable or disable the screen display for each input mode.
  3. Headphone EQ: Added independent EQ for headphone output optimization.
  4. Standby Source Mode: Automatically switch to a selected input when entering standby, enabling instant playback.
  5. Spotify Smart Play: Resume your latest listening session with a single tap.
  6. Surround Setup: Simplified setup with full backward compatibility. (requires upcoming app update).
Screen:
  1. Playback Screen: Added a vinyl-style playback screen for a more immersive experience.
  2. Localization: Added French language support.
Playback & Audio:
  1. Playback Latency: Reduced delay when starting playback.
  2. EQ: Improved responsiveness when adjusting and switching EQ settings.
  3. Line In: Fixed distortion during extended playback sessions.
  4. Bass Output: Fixed low bass levels for Apple TV (Dolby 5.1).
  5. Audio Sync: Improved sync accuracy at microsecond level for better group playback (requires upcoming app update).
Radio & Streaming Services:
  1. TIDAL Connect: Upgraded SDK to resolve unexpected playback interruptions.
  2. Soundtrack: Updated SDK for improved playback stability and performance.
  3. TuneIn: Fixed playback issues for certain stations and improved resume behavior after long pauses.
  4. Deezer: Fixed unexpected playback interruptions.
General Improvements:
  1. Wi-Fi: Improved network stability and enhanced compatibility with Wi-Fi 7 routers.
  2. HDMI ARC: Disabling automatic audio output now correctly keeps WiiM in standby and defaults to the TV speakers.
  3. HTTP Server: Improved concurrency and stability under high load.
  4. Audio Input: Fixed playback crash issues.
  5. Remote: Fixed occasional disconnection and unexpected max volume issues.
  6. Alarm: Fixed incorrect alarm and preset volume behavior.
  7. Roon: Fixed occasional crash issues.
  8. EQ: Enables EQ for Dolby 5.1 playback.
  9. Alarm: Fixes BBC and vTuner alarms defaulting to the chime.
  10. Spectrum Display: Improves dynamic visualization.
  11. Qobuz Connect: Fixed occasional playback stopping issues.
Yes, I have the same settings (for HDMI). Note that my yamaha rxa 2010 is working properly with my TV and my Samsung TV model is quite common and not an old model. I know that wiim is trying to solve the issue and if I understand correctly it has managed to make it work for many different tv models. It is just that they have not managed to make it work for all TV models. Berhaps a hardware restriction? I disconnected the hdmi cable because I cannot have my TV muted for half a minute every time I switch on my TV.
The CEC is turned off by the WiiM, so if the TV tries to connect anyway it's a issue with the ARC settings for the TV. I really don't see what WiiM can do more, as the TV connot connect ARC when CEC is off.
You say that the TV don't try to connect if the cable is disconnected? If so, then the TV somehow can detect the presence of the WiiM without a CEC signal. That is strange.
Yes I do believe that wiim is disabling cec but my TV is using a different way to detect wiim presence, at least for a few seconds. I run some more experiments before giving up. My TV has some hdmi ports that are not arc enabled. If I connect wiim to a non arc-enabled hdmi port of my TV, then when I open my TV, the TV complains that I am using an HDMI port that is not arc-enabled. So my TV does detect the HDMI cable connection to wiim and identifies the fact that wiim is not outputing video. Therefore it urges me to use a port that is arc enabled. So my theory is that Samsung identifies that (a) an hdmi cable is connected to an external device(aka wiim), (b) identifies that wiim is not outputing video therefore is must be an arc device, (c) switches to external speakers mode for a few seconds until an arc time out is triggered and then returns to internal speakers more. Just my guess...
