WiiM Amp Ultra Firmware v5.2.734250 Update - Nov 1, 2025
Please review the WiiM Amp Ultra update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
5.2.734250 (In Progress)
Release date:
11 / 1 / 2025
Highlights: Real-time input status, smarter DNS for reliability, customizable DAC filter, and smoother streaming across services.
What's New:
  1. Input status at a glance: The app now shows when Line In and HDMI ARC are physically connected.
  2. Smart DNS reliability: Validates the DNS server provided by your router for more dependable service access.
  3. DAC filter selection: Choose your preferred DAC filter type to tailor the sound.
  4. Alarms: Custom labels and up to 32 alarms.
  5. Lyrion Media Server (LMS): Disabled by default; enable in Device Settings in the WiiM Home app.
  6. USB Media Library: Create, delete, and manage playlists (add/remove tracks) on USB storage.
  7. TuneIn: Faster start when playing Apple Music stations.
Bug Fixes:
  1. Playback: Corrected playback state display in certain cases.
  2. TuneIn: Now consistently selects the highest available stream quality.
  3. Sub Output: Fixed missing bass when the wireless WiiM Sub Pro was disconnected.
  4. Qobuz Connect: Resolved a blocking issue that prevented playback.
  5. Spotify: Fixed failures to play from the Spotify app’s Recommended lists and Recently Played; also fixed presets that would not start playback.
  6. Alarms: Corrected behavior in Daylight Saving Time zones.
  7. Multi-room: After ungrouping, metadata no longer syncs to previously grouped (child) speakers.
  8. Gapless Player: Fixed a near track end race condition that could trigger overlapping/simultaneous playback.
  9. Local Files: Fixed an issue where the app progress bar reached the end before playback finished.
  10. Amazon Music: Smoother seeking and playback—fixed occasional skips after seeking, progress bar desync, repeated playback of the same track after seeking, and unexpected stops when using Amazon Music Cast.
And just in case anybody else new to WiiM devices might have the same question:
The setting can be found in Device Settings (the cog/gear icon) => Audio Output => DAC Digital Filter Type.
Wasn't that already there? Didn't they recently add the "corrected minimum phase fast roll-off filter" option? I seem to recall it being added because I chose it since it says corrected and none of the others do... so they must be wrong?! Right??!!😁
Is there anyone here who has a problem with the WiiM Amp Ultra that emits pop noise when turning on or off the HDMI mode? It appeared for me and quite often when HDMI mode is activated I hear unpleasant pop noise in the speakers.
I don't know since when this happened. I have the latest version of the software, I have already sent feedback to WiiM, but I don't know if I'm the only one who has it or what happened?
______
EDIT:
OK, I changed Standby Mode to 30 seconds and now I see that when activating the standby state and deactivating this state, it is the same like for HDMI input. It doesn't matter if it's HDMI or Spotify Connect, for example. It's always pop noise when switch on or off standby mode.
Hmm, does that mean that some WiiM Amp Ultra units have a defect?
Sorry, I should have been clearer.
I get this with some of my amps across multiple manufactures / brands.
Seems to be quite common, perhaps moreso depending on design.
I'm sure an internet search will give technical reasons why.
Just a comment and kudos to @WiiM Team! The addition of
is a great feature. The chance to select a linear phase filter very welcome!
P.S. - Will this DAC filter selection be also made available on the AP A10 II WiiM Edition?
Can you really tell the difference if you are over 10 years old? 🙂
When listening, most people focus on some baseline tonality and frequency response and that's why a single SINAD number satisfies them. However, great sound playback depends on phase preservation for spatial cues and transient response. Do I hear a linear phase vs minimal phase? Yes I do and of course the better the DAC implementation the more apparent those differences are. It has nothing to do with auditory age.
All D-class amplifiers with PFFB that I own (or have owned) produce popping sounds. I believe this is not a problem.
@Burnside,
My dog is elderly and requires a hearing aid.
If my memory correctly, you were the only one to pass the blind test conducted by @onlyoneme. 🙂
Wiim Amp Ultra
When pressing the remote's power button on/off, no pop sound is emitted. Please set the auto standby to 30 seconds and check whether a pop sound is audible from the speakers when the Amp enters standby mode. (Play music, pause, and wait for it to enter standby mode.)
  • Like
Reactions: d00
In fact, there is a barely audible knock.
Maybe yours is excellent. 🙂
I can hear the pop of mine well.
I can hear also and it is really annoying. I had a WiiM Ultra + WiiM Vibelink Amp and I don't remember such pop noise. It seems to me that it shouldn't be like this and it's some kind of problem - I just don't know if it's software or hardware issue.
