WiiM Pro or Pro Plus
Ivkyy1
Hi!
Just to ask before i buy any ....WiiM Pro or Pro Plus if I connect the device to a Yamaha A-S501 integrated amplifier. I'm asking this because I don't know if it's worth paying more for the Pro Plus because of the DAC it has and how can I tell if it's better than the Yamaha DAC amplifier...
Ah right. So this could not be paired with a Vibelink if a sub was wanted? This will only work with a Wiim Ultra / Vibelink?
Sorry, to be clearer - while the pro plus doesn't have a sub out like the Ultra, you could use the WiiM Sub Pro wirelessly paired with the pro plus.
Quick question - if you’re running a sub, did you connect that to the Pro Plus or the Yammy? I’m thinking of hooking a Pro Plus to my Yammy RX-V585. Thanks.
As Burnside has said, pro plus doesn't have a physical sub out. I used an ultra with my yammy and had tge sub run from that. When I used a mini with the yummy it was in my office system without a sub. So in your case, just use the yummy AVR for sub out.
Thanks for clarifying.
