I just purchased this and it worked fine for about an hour or so then it would disconnect from the Spotify app. I went to the WiiM app and it couldn’t find the device saying it was offline.
The only way to correct the issue was to unplug and plug it back in and sometimes I had to set it up again using the app. It has the latest firmware and seems very unstable. I had a Bluesound in the same location and it worked without any issues.
I’m tempted to return it.
