WiiM will announce the ProPlus soon and Roon Readiness will be delivered via an OTA update after that, hopefully in a matter of weeks.Per the Roon forums, apparently the new Pro Plus device has to go through Roon Ready certification again, but should be quicker as the software is likely to be the same. Hopefully will come to market soon (assuming the delay is due to this).
Can't wait, finally we can experience the "velvet" AKM sound without breaking the bank with expensive DACs.WiiM will announce the ProPlus soon and Roon Readiness will be delivered via an OTA update after that, hopefully in a matter of weeks.
There are inexpensive DACs with velvetsound line chips from AKM, like SMSL PO100 AK or SU-1.Can't wait, finally we can experience the "velvet" AKM sound without breaking the bank with expensive DACs.
The last time I checked, even those AKM "hats" for RiP boards are more expensive than Pro+ itself but without all the convenience and features of Pro+, so I think the Pro+ will be another winner by Wiim!
And there are relatively expensive amps/streamers like those from Linn that use(d) AKM4493EQ DACs as well - those might even be what are used in my £3k Linn MDSM/4, but has been said before there’s more to DAC kit than just its core chip.There are inexpensive DACs with velvetsound line chips from AKM, like SMSL PO100 AK or SU-1.
The power supply is external, so you can add one at your whim, though it will make a difference only in the imagination.I just hope WiiM has implemented everything well including a “linear power supply” upgrade option which I read may make a big difference?
If it doesn’t make a difference, then it’s great news. More money saved with the new Pro+ path.The power supply is external, so you can add one at your whim, though it will make a difference only in the imagination.
There are a lot of know-nothings out there. See ASR for science-based information on why this doesn’t make a difference.If it doesn’t make a difference, then it’s great news. More money saved with the new Pro+ path.
But lots of YouTubers and forums claim power supply make a HUGE difference, why is this the case?
Yes, but the answer was about the possibility to get a "velvetsound" solution already "without breaking the bank with expensive DACs", nothing more.And there are relatively expensive amps/streamers like those from Linn that use(d) AKM4493EQ DACs as well - those might even be what are used in my £3k Linn MDSM/4, but has been said before there’s more to DAC kit than just its core chip.
The top buttons can control volume, can't they?If anything is missing from the Pro, and I understand it will be missing from the Pro+ as well, is the volume control (physical, analog) and the headphone jack. For the rest I think that at this price you really can't ask for more.
These two absences are actually quite annoying, but not to the point of causing its value to plummet.
I specified "physical", i.e. with a potentiometerThe top buttons can control volume, can't they?
Or prev / next track.
But not both!
Yeah, ok, "physical analog". I understand nowI specified "physical", i.e. with a potentiometer
No name calling allowed... !May be a simple knob is meant![]()
