D
Deleted member 2191
Guest
Yessss, a knobMay be a simple knob is meant![]()
But I had to specify "physical" because the non-physical one is already there.
So... if wiim do create a dac-less pro, what would it be called?pros and cons...
I don't fight battles over such modest things, in fact I have said that its absence does not cause the value to collapse.Hopefully a next battlefield will not be openeddigital vs analog volume controls. Another never ending story about pros and cons...
I was merely saying that there are expensive combos too in juxtaposition to your statement that there are cheap options, not necessarily in response to the original questionYes, but the answer was about the possibility to get a "velvetsound" solution already "without breaking the bank with expensive DACs", nothing more.
I haven't opened my Wiim Pro yet, so I don't know how much free space is available.It was more a general hope, not related to your posts. But in contradiction to the empathic phrase that hope would die last I decided for me to let hope die and wait for facts![]()
Will there be any impact in the performance, when an headphone Amp along the DAC implemented in a streamer or Desktop DAC ?I haven't opened my Wiim Pro yet, so I don't know how much free space is available.
If there's space, adding a 15V power outlet and a small MOSFET class A headphone amplifier is simple.
On the front panel there is plenty of space for the headphones jack.
Sure. Usually the same chips are used, although the devices that implement them can vary greatly in price.I was merely saying that there are expensive combos too in juxtaposition to your statement that there are cheap options, not necessarily in response to the original question![]()
Somewhere I read that there is some difference in the performance of a DAC with /without an headphone Amp
I don't know how far it is true, neither I have checked it nor I'm a tech guy
Knowledgeable people can clarify the same
TIA
I think that without integrated DAC only family members of the designers would buy itMaybe they could bifurcate this - AIO solution one product and no DAC built-in another product but with USB-C out.
I’d guess WiiM have a pretty good idea of 1…Two surveys have to be done.
1.Percentage of wiim mini/pro users that use the built in dac.
2. Same for wiim pro plus after time passes .
Don't confuse what customers use with what know they bought with their money.Two surveys have to be done.
You mean it shows in the usage statistics from the mobile app?I’d guess WiiM have a pretty good idea of 1…
I don’t know but I would expect soYou mean it shows in the usage statistics from the mobile app?
at 220 dollars or 250 euro significantly changes the situationAudiophonics listed price: 250 euros
WIIM PRO+ Streamer
The WiiM Pro+ (PLUS) is a compact, extremely versatile and high-performance audiophile network player that transforms a conventional audio system into a connected system.www.audiophonics.fr
The WiiM Pro+ is a compact, extremely versatile and high-performance audiophile streamer that transforms a conventional audio system into a connected system. It opens the door to music streaming via WiFi and Bluetooth 5.0, and is compatible with numerous transmission modes such as DLNA/UPnP, AirPlay 2, Google Chromecast, Alexa Music Cast, Spotify Connect and Tidal Connect. Several units can also be used in combination to set up a true multi-room system, with full remote control via the WiiM App mobile application or a voice assistant such as Alexa, Google Assistant or Siri.
The WiiM Pro+ is an improved version of the WiiM Pro, incorporating a better DAC and ADC as well as more efficient OPAs. Its performance, particularly with regard to its line input and output, has been revised upwards, with improved SNR and THD+N for even more accurate and transparent sound reproduction. The main improvements to the WiiM Pro+ are :
- A better ADC for line input: WiiM Pro+ uses a TI Burr-Brown PCM1861 ADC, supporting 32bit 192kHz PCM streams at output, with an SNR of 110dB.
- Ultra-low-noise clock, power supply and circuitry: The WiiM Pro+ features an ultra-low-noise clock and power supply and a PCB design optimised to achieve a THD+N of less than -110dB for the analogue output.
- AKM DAC and TI OPAs for improved line output quality: A new-generation AKM AK4493SEQ DAC is now used to achieve a very low level of distortion and a wide dynamic range thanks to AKM Velvet Sound technology. This chip supports PCM streams up to 768kHz and DSD up to DSD512 while achieving an SNR of 120dB (A-wt) and a THD+N of -110dB.
- Remote control: A voice remote control is now included, allowing you to control the WiiM Pro+ from the comfort of your sofa, without having to take out your phone.
the exchange rate is 1euro=1.09 dollars therefore 274 almost not 220at 220 dollars or 250 euro significantly changes the situation
