MrSoul4470
Active member
For digital output it most probably doesn't matter at all. And in case you use the analog output: The analog section of this device is so bad, you really don't have to worry about the power supply.
I did some tests with different power supplies in the past. The cheap switching ones sounded the best and the linear power supplies always sounded worse.
