Wiim Ultra- bugs / strange behaviour of local files library (from USB)
incans
I've only had the Wiim Ultra about a month, so still finding my way around. For many years (pre-Wiim) i've been streaming my local music (ripped CDs) from a server running either Plex or miniDLNA. The core library consists 3000 or so tracks, 90%+ of which are FLAC ripped from CD, plus a few individual tracks in MP3. My servers are currently out of action, but given the Ultra has a USB port that's compatible with USB storage, I thought I could just dump my music library onto a big memory stick, and Bob's Your Uncle...
This partially works, but I have found the behaviour of the Wiim librarian and local file player features to have some bugs, or possibly "features"?
  1. Most annoying is the fact that the library fails to see and index quite a few files that are on the memory stick. For example I have the album "Marc Cohn" (by Marc Cohn) on the USB stick, comprising 11 FLAC files. However the Wiim library only acknowledges 6 of them.
    Incredibly, it manages to NOT let me see and play my favourite tracks on this album! (I'm just wondering now if the Wiim somehow chokes on files that have a tag for a high 5-star rating applied by MediaMonkey. That would be pretty ironic.)
  2. After I attached the USB stick for the first time and indexed the contents, I was very surprised to find that I could unplug the USB stick and take it away, but the Wiim would still list AND play the content?! I asume this mean the Wiim doesn't just "index" a source device, it actually copies the data into a local cache on the device. That's ok but-
    a) What happens if the USB device (say a USB portable hard disk) is much larger than the Ultra's internal memory?
    b) How do you clear out files that have been cached locally, but you have changed or deleted the file on the memory stick?
    c) Is there any way to get stats on the library? (e.g. % of capacity used, no of "stale" tracks buffered locally)?
  3. A library of decent size is almost bound to include near-duplicates, e.g. the same track on different albums. The Wiim just shows these in a single flat track list. This isn't very helpful. For example I have a AC/DC live compilation album that contains the same track 6 times. The Wiim lists these with identical track names and artists (not unreasonably), which makes it impossible to make a meaningful choice.
    My preference would be for tracks that are "the same" (based on a rule such as artist name+track name) to be listed as a single entry for the track, with a sub-list showing the key fields that might differ such as-
    a) Album artist(s)
    b) File format, bit rate, (dynamic range?)
    c) Track length
I can't believe I am the only user to have run into these issues. Are they well-known problems, and any comment from Wiim on whether they are going to be worked on?
Note: The tag "usb output" makes no sense, but I can't find a tag that does relate to this issue, and the forum seems to insist on having a pre-existing tag assigned to every post.
Again, show us your files, folder structure and tagging.
Or you can keep on braggin‘ on how things don‘t work.
I don't boast..
I'm not complaining, it just annoys me because I lose a lot of time that I don't have with other devices.
The folders that the Wii has
Gehe über Ordner alles okay
Jedoch über Alben nichts okay
Andere Strukturen sehe ich oder finde ich nicht
Looking at your latest pics I see iTunes.
This is where your problem lies.
Apple is no good for file management and iTunes the death of any library management.
Absolutely! iTunes / Music also stores artwork separately and makes it incompatible with anything else.
I'm a bit at a loss now.
1. The albums on the hard drives are exclusively ripped CDs from my old collection. The programme that provided the metadata was XLD & included a database (Musibrainz?).
2. Both the old and new Mac Minis are designed exclusively for music, and the necessary data is provided by a streaming service; otherwise, the programmes that are not needed are shut down. I have not used a database in over 11 years, in the sense of ripping or importing.
Audirvana has been instructed not to pair with iTunes.
Since external music player software such as Pure Music / Amarra AND Audirvana became available, I no longer use iTunes.
Hmm, why does this work for USB under the Folder item, but not under the Album item?
Can you actually post a ripped file that is displaying the wrong details and album art or can you confirm that you have actually checked the metadata on a file with an appropriate tool to verify that it is as it should be ?
AFAIK there are not widespread reports of the issues you are experiencing so there is something about your files that causing this behaviour
You may have acted in good intention. But I‘m afraid, in vain.
Apple uses a proprietary file storage system and tagging is all over the place, no matter how good the source was.
Get a Windows PC, load your files or what‘s left of it and see what you can make of it. Then get foobar or MP3Tag to get the tagging right.
First of all, thank you very much for your help.
You shouldn't change a system that works well... gentlemen... I'm staying with Apple / Audirvana / Qobuz, which is great thanks to Audirvana Studio.
Thank you for everything.
Under the folder item, it´ s all okay ( right)
Under the folder Album, it´ s Chaos ( left)
It's nice of you to be thankful. But it doesn't make sense to stay with a concept that's proven broken (Apple iTunes).
The irony is that there have been multiple little oddities with WiiM's implementation of the MiniDLNA server. These are mostly fixed now. But if the tagging of your original files is messed up, this is what you get as a result. It's the old concept of gold in, gold out.
The irony is that there have been multiple little oddities with WiiM's implementation of the MiniDLNA server. These are mostly fixed now. But if the tagging of your original files are messed up, this is what you get as a result. It's the old concept of gold in, gold out.
No one forced me to change the existing system. I tried it
Outside of the Wiim system, I don't have any problems with external data if I want to use it .
But what's even more serious is that the Wiim DSP can't solve the "problem" of subwoofer integration, while others can.
As you already wrote, gold in, gold out.
All your off-topic comments regarding this "problem" have remained unclear so far, to say the least.
You're not going to gain WiiM's attention by spreading unrelated and impossible to understand snippets wherever you go. :)
That's just my personal guess, I might be wrong.
Correct. For me, the technical performance was fragmented; nothing fit together as it should.
I was completely surprised by this.
When I look at the forum, there are various threads that could fall under one topic...
Back to the topic at hand: external USB library.
The statement that Apple is an unsuitable audio system borders on bashing.
According to users, something that supposedly couldn't work due to the Apple system is now working. And it works just as well as the Wii device, even in terms of sound.
Cloudy, to say the least.
Nobody said so.
Nobody said that anything related to Apple couldn't work. The fact you've chosen to ignore is that the WiiM media server built into the WiiM Amp, the WiiM Amp Pro, the WiiM Ultra and the WiiM Amp Ultra relies on correctly managed ID3 tags (and half reasonable file and folder names). Other systems (in particular those using online services to retrieve file tags) may work well even if the tags embedded in your local files are broken.
    a) Album artist(s)
    c) Track length
All I can say is, Buckle Up it's gonna be a bumpy ride. This thing has been out for quite a while now, and it still isn't Ready for Primetime. I have so many problems with this thing. File management is the biggest headache of them all though. I won't bore you with the details, but let's just say I don't rely on it very much anymore. For the expense, I was really hoping for it to be razor-smooth across the board. Unfortunately, all I ever get from "SUPPORT" is a carbon-copy reply telling me to update the app or the firmware. Ironically, I usually have already done both. They have a whole book of excuses for why something(anything) doesn't work right. I could go on and on, but I just wanted to let you know that you are not alone.
    a) Album artist(s)
    c) Track length
I got Wiim Ultra a week ago. One of the first things I made was to connect my usb hard disk. The disk contains three main folders with many sub folders inside. Music files are 40.000 less or more but after the first scan (4 hours) Wiim Ultra can see only 29.000 of them, only one folder with a part of sub folders choosen randomly. It seems that the scan doesn't run in alphabetical order, or timestamp order, or any other order.
So I remade the scan and the result was exactly the same.
I hope that this is a fault, or a misconfiguration, because if it is a limitation it can be a reason to give back the product. New investigations and test on next days.
If you have a large collection of local files plugging a drive into the WiiM device is often not the best option. Using a server generally gives a much better experience.
