This targets the Inovato Quadra, which is essentially an inexpensive Android TV box running a Linux variant.Any chance you could create a simple full screen Android TV app for this as well? Would be amazing! If not, I'll try to look into it myself. Eager to learn!
I've just tried sideloading the WiiM Home app on my Chromecast with Google TV, but it's not ideal
Whereas I trialed Deezer a month or so ago and gave up on it partly because of Flow.I had a sub to Deezer years ago, IIRC an annual sub that was super inexpensive due to some sort of discount. I remember at the time, Flow would start out playing what I liked, then would start playing completely unrelated garbage. I had to give up on it as a result. I've been listening to Flow the last couple of days - looks like that nasty old habit has perhaps been fixed. We'll see. Zero ads so far, freebie account, 128kbps. Nice "radio" for background music.
No, unless you’re playing music in an Alexa multi room music group with your Show and Wiim, but be aware that will be limited to 16/48 at best using a WiiM Pro, and lossy SD if using a WiiM Mini. The echo shows are primarily display interfaces to Alexa, don’t run apps and aren’t general purpose devices where you can easily do things like that,I really like the idea of having what's playing on the Wiim being displayed on another device with a screen, unfortunately the device I wanted to use is too old for this app or for the Wiim app, is it possible to display what's playing on an Echo show?
Why there is such difference between WiiM Pro and WiiM Mini?No, unless you’re playing music in an Alexa multi room music group with your Show and Wiim, but be aware that will be limited to 16/48 at best using a WiiM Pro, and lossy SD if using a WiiM Mini. The echo shows are primarily display interfaces to Alexa, don’t run apps and aren’t general purpose devices where you can easily do things like that,
Lack of memory in the WiiM Mini to support Amazon Music’s higher res tracks in an Alexa multi room music (MRM) group. Plus even with the Pro, Amazon seems to limit MRM playback to 24/48.Why there is such difference between WiiM Pro and WiiM Mini?
