Thanks for the reply, what a shame, would have been an easy solutionNo, unless you’re playing music in an Alexa multi room music group with your Show and Wiim, but be aware that will be limited to 16/48 at best using a WiiM Pro, and lossy SD if using a WiiM Mini. The echo shows are primarily display interfaces to Alexa, don’t run apps and aren’t general purpose devices where you can easily do things like that,
I use Tidal anyway so presumably it would not work in anyway?
I might end up buying an secondhand small tablet then.
