EddNog
Senior Contributor
Those definitely do.Don't usb-c cables that come with Apple products have the correct chips in them?
-Ed
So if I’m connecting my MacBook via Apple usb-c to SMSL PO100>to Ultra via optical>to DAC via COAX I should be able to stream hi-res Apple Music correct?Those definitely do.
-Ed
Correct.So if I’m connecting my MacBook via Apple usb-c to SMSL PO100>to Ultra via optical>to DAC via COAX I should be able to stream hi-res Apple Music correct?
Okay, sorry; I didn’t pay enough attention with my previous response.Well I'm still having a problem with streaming hi-res Apple Music using the cable that came with my Macbook. According to a little research, not all Apple cables have an e marker chip, and perhaps the issue.
Okay…this is a first I’ve ever heard of this problem. I use all sorts of random USB-C cables with my MacBook Air M1 (Audirvāna playback which locks the output device and plays bit-perfect high-res lossless without issue) as well as with my iPhone and iPad to external DACs and also DAC dongles and never had an issue. And I am definitely talking about a huge variety of cables from expensive, “hifi-grade,” stuff to some cheap crap that came with a $5 charger from the dollar store.Same issue with iPhone using Apple usb-c from phone to PO100. Still not getting lossless.
It's really not a big deal because I use Qobuz anyway and I have no issues with it and the PO100. From what little research I did it seems that not all Apple cables have the proper chip and therefore might not be hi-res friendly on Apple devices connected to the PO100.
My MacBook plays hi-res fine. It's getting it to my DAC that's the problem presently. While I didn't buy the PO100 for that purpose originally, but rather to experiment with reclocking on my Ultra, when I heard that it could also be used with Apple devices by connecting it's usb-c out to the PO100 and then connecting either Coax or toslink to my DAC. But no luck there, and no luck connecting my Macbook or iPhone usb-c to PO100 then to DAC getting hi-res through Apple. I can get hi-res with Qobuz using Ultra>PO100>DAC.Okay…this is a first I’ve ever heard of this problem. I use all sorts of random USB-C cables with my MacBook Air M1 (Audirvāna playback which locks the output device and plays bit-perfect high-res lossless without issue) as well as with my iPhone and iPad to external DACs and also DAC dongles and never had an issue. And I am definitely talking about a huge variety of cables from expensive, “hifi-grade,” stuff to some cheap crap that came with a $5 charger from the dollar store.
However, I have always had issues with the iTunes app playing high-res on my MacBook. It works perfectly fine on my iPhone and iPad, though, and always has.
-Ed
This is an external DAC (as opposed to WiiM Ultra)? Why not just go straight USB to the DAC? Or is the USB used up by something else? Almost all modern DACs have USB in.My MacBook plays hi-res fine. It's getting it to my DAC that's the problem presently. While I didn't buy the PO100 for that purpose originally, but rather to experiment with reclocking on my Ultra, when I heard that it could also be used with Apple devices by connecting it's usb-c out to the PO100 and then connecting either Coax or toslink to my DAC. But no luck there, and no luck connecting my Macbook or iPhone usb-c to PO100 then to DAC getting hi-res through Apple. I can get hi-res with Qobuz using Ultra>PO100>DAC.
I wonder what the difference is between the Cubilux device and the PO100?
No it's not a DAC. It's used for it's clocking with the assumption that the clock(or lack of one thereof) is not as good in the Ultra. I normally go from Ultra to the DAC via USB. Now I'm using the USB out of Ultra into the the PO100 then optical out to DAC.This is an external DAC (as opposed to WiiM Ultra)? Why not just go straight USB to the DAC? Or is the USB used up by something else? Almost all modern DACs have USB in.
-Ed
Unfortunately, it does not. Lossless is capped off (with AirPlay 1) I believe either at RedBook (44.1/16) or at 48/24.I would like Apple Music if only their airplay can support 24/192.
Right; my point was that you can forego the PO100 Pro as well as the WiiM when going out of the laptop to the external DAC.No it's not a DAC. It's used for its clocking with the assumption that the clock(or lack of one thereof) is not as good in the Ultra. I normally go from Ultra to the DAC via USB. Now I'm using the USB out of Ultra into the the PO100 then optical out to DAC
It works fine wired. Yes, unfortunately, it does not work wirelessly.They offer high resolution loseless but only be disappointed because it can’t deliver high resolution because of their airplay.
And when you go straight to the Denafrips from an iPhone or iPad using USB-C, don’t you get high-res?I've tried that with a usb-c to usb-2.0 to Denafrips Ares II DAC and no hi-res.
I simply make sure the adapter is getting external power separately, then in the Music app, on the currently playing view (the screen that shows either the album cover, the lyrics, or the queue), tap the middle symbol at the bottom, which is like 3 concentric circles with a triangle pointing into the middle of it, then tap on the Cubilux adapter there and it should work.So after not having luck using the PO100 in getting hi-res Apple Music from my iPhone to the Ultra(Macbook works fine) I broke down and bought the adapter described in the OP. Still no luck. I think the problem might be that the iPhone is using Airplay to use the adapter and I don't know how to stop that. Or maybe not the problem.
@EddNog perhaps you can tell me what your settings on your iPhone are to get Apple Music to play hi-res? I'm using a 16 Pro.
Thanks.I simply make sure the adapter is getting external power separately, then in the Music app, on the currently playing view (the screen that shows either the album cover, the lyrics, or the queue), tap the middle symbol at the bottom, which is like 3 concentric circles with a triangle pointing into the middle of it, then tap on the Cubilux adapter there and it should work.
Did you make sure to go to the phone's Settings console, scroll down to the bottom, tap Apps, scroll down to Music, tap that, scroll to Audio, then tap Audio Quality, and make sure you have Lossless Audio enabled at the top and then Hi-Res Lossless selected for all streaming options?
-Ed
