It does I have it on my ultra. You need put location on ultra like bedroom then you will see the option.That option does not exist for my WiiM Ultra.
I didn't try setting my phone to Polish language, though.![]()
Android or iOS?It does I have it on my ultra. You need put location on ultra like bedroom then you will see the option.
There may be another reason. I read somewhere that Google stopped supporting Chromecast Audio. Maybe that's why it's not on Android devices. Maybe they left it on iOS on purpose? A few years ago I read on some forum that this setting is important for high sound quality, because the default is low quality.I conclude that this setting is simply superfluous for Android as Chromecast will always use the "full dynamic range" (whatever the restriction posed by the opposite might actually be).
Nope, not on Android.It does I have it on my ultra. You need put location on ultra like bedroom then you will see the option.
Why would they leave it on iOS?There may be another reason. I read somewhere that Google stopped supporting Chromecast Audio. Maybe that's why it's not on Android devices. Maybe they left it on iOS on purpose? A few years ago I read on some forum that this setting is important for high sound quality, because the default is low quality.
iOSAndroid or iOS?
Chromecast Audio had better specifications:Chromecast Audio was a product, which Google stopped making and eventually supporting. Chromecast built-in (as it once was called, I have no idea if or how many times they might have changed the name) is a different story (but also audio only).
And it's lossless, currently supporting 16 bit 48 kHz using the Ultra. I cannot imagine what dynamic range would need improvement here.![]()
āChromecast audio specifications
Below are the specifications that work with Chromecast Audio:
Output
- Stereo analog output: 2Vrms
- Optical digital output
- High-resolution audio: 96 KHz / 24-bit
Supported audio formats
- HE-AAC
- LC-AAC
- MP3
- Vorbis
- WAV (LPCM)
- Opus
- FLAC with support for high-resolution streams (24-bit / 96 KHz)ā
When I use chromecast on qoboz app, high resolution doesnāt show number even on wiim app. Iām not sure what resolution itās playing. This is on ultra.Chromecast audio on other WiiM devices supports up to 24/196 despite that (outdated?) spec. WiiM are working on improving Chromecast for the Ultra.
A while back WiiM removed bitrate/ resolution info for Chromecast from the WiiM app as they couldnāt be sure it was accurate. However, from memory, the Qobuz app will show the playing resolution albeit just up to 24/96 as thatās what its app caps Chromecast at.When I use chromecast on qoboz app, high resolution doesnāt show number even on wiim app. Iām not sure what resolution itās playing. This is on ultra.
The qoboz app when I play high 24/96 via chromecast itās down sample it to ācd qualityā I tried several music and all came the same cd quality. If I play it via wiim app it play on its native resolution. Iām not sure why chromecast down sample music to cd quality. Now, if I play it on my my phone itās fine with correct information.A while back WiiM removed bitrate/ resolution info for Chromecast from the WiiM app as they couldnāt be sure it was accurate. However, from memory, the Qobuz app will show the playing resolution albeit just up to 24/96 as thatās what its app caps Chromecast at.
I tried it while playing music using toggle on and off it did not change any behavior from loud to soft passage. There was no effect. To me itās just light show thinking you get full range.My understanding is that "full dynamic range" is the normal audio output. Nothing special. Turning it off narrows the range and eliminates distortion on small speakers, etc. It may look a little like normalization.
Yes, someone correct me if I am wrong.![]()
Yeah, sorry thatās currently a restriction with Chromecast (or CastLite) only on the Ultra - shouldāve mentioned thatā¦The qoboz app when I play high 24/96 via chromecast itās down sample it to ācd qualityā I tried several music and all came the same cd quality. If I play it via wiim app it play on its native resolution. Iām not sure why chromecast down sample music to cd quality. Now, if I play it on my my phone itās fine with correct information.
Hmm, ultra got less quality chromecast than the rest of the wiim. Thatās suck!Yeah, sorry thatās currently a restriction with Chromecast (or CastLite) only on the Ultra - shouldāve mentioned thatā¦
No - a DAC converts digital to analog by definition and if it the output is digital, Iād say itās not being used and that the upsampling is being achieved computationallyIf fixed resolution is upsampling everything, dose that mean the Wiim dac is being used and not bypassed although I am using digital out on my Pro.
To my opinion the only way I would use such feature if your hearing pop and click when changing music with different samples.If fixed resolution is upsampling everything, dose that mean the Wiim dac is being used and not bypassed although I am using digital out on my Pro.
