slartibartfast
- Apr 18, 2024
So why is yours correcting below the crossover when mine isn't? It was with the beta.correct 82hz
Two of those show correction below crossover and the other two don't.here are four screenshots for room correction I ran using an imm6 Mic and the microphone built in on two different phones. Samsung s23 (with apple USB c to 3.5)and Samsung s10e with the latest wiim update.
very observant. the one to correct below the crossover point was only done on the Samsung s10e with internal mic and with imm6. very strange.Two of those show correction below crossover and the other two don't.
Does the S10E have the latest app update?here is four screenshots for room correction I ran using an imm6 Mic and the microphone built in on two different phones. Samsung s23 and Samsung s10e with the latest wiim update.
of course, both phones running identical wiim version and settingsDoes the S10E have the latest app update?
Android 7?? Come on. Current OS is 15...On my Galaxy S5 running Android 7.1.2 I can't get past this stage. The "Next" box is missing.
They say it runs on 7.0Android 7?? Come on. Current OS is 15...
Hmm. Maybe notThey say it runs on 7.0
It seems like the resolution is wrong and the "Next" box is off the bottom of the screen. I just wanted to try another phone to see if the RC corrected below the crossover.Hmm. Maybe not![]()
Very outdated os and phone. I replace my phone when the battery dip down 80% on iPhone.Android 7?? Come on. Current OS is 15...
I know but it should work.Very outdated os and phone. I replace my phone when the battery dip down 80% on iPhone.
It only obsolete if the thing you want for the device doesn’t work.I know but it should work.
It has an IR blasterIt only obsolete if the thing you want for the device doesn’t work.
WiiM say it runs on 7.0.That's the problem with phone os and closed source apps they're not backwards compatible.
It should be obsolete when you get years beyond a security update (unless you stay off the internet). I have an LG V30 and Pixel 2 which do still work but they don't get used.It only obsolete if the thing you want for the device doesn’t work.
