This is a simple question, but does the delay time change if the subwoofer volume is different?Apparently it doesn't choose a level that doesn't need boosting. All reports so far make it sound fairly useless particularly as you can't separate the level and timing.
For example, if the Ultra volume remains at 80%, will the delay time differ between when the subwoofer volume is set to 0 dB and when it is set to -5 dB?
If the delay time remains constant, then all I need to do after calibration is simply set the subwoofer volume back to 0 dB.
